Question about Honeywell Air Purifiers
HOW DO YOU RESET MACHINE AFTER INSTALLING NEW FILTER
    Scholar:
  • 185 Answers
Try unplugging it, then wait a few munites,then plug it in again.
If that does not do it, see if the switch has a reset position and they turn it to that point.
Posted on Feb 02, 2010
Problems installing water filtration replacement filter GE gxulqr
After you shut the water off, unscrew the canister, remove old filter and check it against new filter. (They should be the same) check fo arrows (if there are any point in upward position) insert and screw canister back on, fasten securely, turn water back on.
Jun 27, 2014 | GE SmartWater GXULQR Replacement Water...
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
My Holmes HAP9412bf air purifier 'filter status' light does not reset with new filter
while running, press and hold the filter reset button for 3 seconds.
Oct 01, 2013 | Air Purifiers
Yesterday, I purchased a new RCI filter and replaced it and the light of the new filter does not light when turned on and the machine says replace RCI filter as it did when it quit working..Thanks.
Perhaps, the tab on the filter frame, that triggers the safety switch is not making contact. Remove the filter and reinstall the filter. Make sure you push the tab firmly into the trigger slot. That should solve your problem. Please let me know.
Mar 17, 2011 | Ecoquest Fresh Air Air Purifier
I have the same problem. I replaced the lamp and starter with new . But after I press the button reset the mesage replace the lamp continue to show it and the blue light is missing (INSIDE THE BOX)with any...
It may be that the bulb and starter are not inserted correctly. The message indicates that something is not making contact. Make sure they are seated properly and firmly. They need to be twisted, like installing a fluorescent light bulb.
If the bulb begins functioning, but you are still seeing the message, push the reset button, then turn the machine off for a minute or two. If everything is installed correctly, the light should work, and the message should be removed.
Jan 14, 2011 | Ecoquest Fresh Air Air Purifier
How do you reset the machine, to get rid of the flashing red light after changing the filter?
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 09, 2010 | Filter Queen Defender Air Purifier
How do I reset the "replace filter" light? I put a new filter in an don't know how to make the red light go out. Thank you
With the unit on - take off the front panel - right under where the "replace filter" light is, there is a button that says "Reset" hold that button in until it beeps - then the light should turn off. Hope this helps :)
Jul 31, 2010 | Winix PlasmaWave 5000 Air Purifier
V5 filter replace - how to reset red flashing light?
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
  • At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
  • At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
  • Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
  • At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
  • To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/IQAir-healthpro-plus-owners-manual.pdf
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
Chris J.
GoVacuum
Apr 08, 2010 | IQAir HealthPro Plus Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Cleaning the filter
    Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
    Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
    Air Purifiers Logo
    926 people viewed this question
    Top Honeywell Air Purifiers Experts
    Bill Long
    Jay Finke
    Jay Finke
    Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
