Question about Dishwashers
MDBH970AWW MT DW: UPPER RACK W10269678 ROLLERS ARE TOO SMALL TO STAY IN UPPER TRACK
3 Suggested Answers
SOURCE: 2 upper rack rollers cracked in Maytag #MDB7600AWS
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Posted on Dec 14, 2009
  • 35 Answers
SOURCE: upper rack assembly rail continuously comes off
Check the rollers they may need replacing.
Posted on Jan 06, 2010
How do I get the upper rack arm back on the rollers?
The back endcap on the slider has snaplocks that has to be squeezed then pull off. This should allow you to pull the slider out and then guild it back over the rollers and into its proper place. Just had to do this, and it's hard to get to with the door down, but can be done.
Jan 13, 2015 | Dishwashers
Top rack automatically slides out upon opening door
This is actually a feature to allow the user easy access of sliding out the top rack. A look at the parts diagram disclosed that there is no mechanism activating this and therefore could be assumed to be gravity driven. It would stop a few inches due to the action or rather inaction of the rollers which would require user intervention (pull).
The only modification I could think of is to change how the inner rails are attached by inclining it to prevent the sliding out. The idea would be to lean in the upper rack to prevent gravity from sliding it out. Am not sure if inclining the entire dishwasher would affect the overall performance but it is also a possibility.
I have taken the liberty of including the diagram of the upper track should you wish to reference it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | GE PDW8680NSS Built-in Dishwasher
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
GE Adora Dishwasher Upper Rack Binding Issue
I have a GE Profile model PDW7800.... and just replaced the rollers on one side since one of them had broken. There is a 'magical' way to reinstall the rack so the side guides ride inside the roller guides without touching. I suspect that the rack has not been reinstalled in the precise manner - which I am still trying to figure out. The new roller assembly which attach to the rack fit differently than the original ones. I found that you do have to remove the rollers screwed into the wall to get the glides out and that could also cause rough gliding. Part of the 'binding' is designed, I believe, to keep the racks from coming out too easily.
Sep 17, 2008 | Dishwashers
CAN NOT REMOVE THE END CAPS FROM TOP RACK TO REPLACE THE ROLLERS
The end caps on the upper rack of my GE dishwasher do not pull off, they "rotate" off by turning the top of the cap toward the center of the dishwasher. In order to make this rotation, you need to slip a small screwdriver in the track to the inside of the nipple at the top of the back of the end cap and force the nipple toward the middle of the dishwasher.
DBK
Aug 29, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
I have Kitchen Aid Dishwasher Model # KUDMOITJBLO. We began having trouble with the top rack coming out of the brackets on the upper rack track. Kitchen Aid sent me 4 parts # 8268785. The problem is...
I removed the tracks from inside the dishwasher.  Then I was able to carefully remove the endcaps (something I had not been able to do previously) carefully.  The existing broken wheels slid out and I slid two new brackets into each track.   If I attached the tracks to the rack first, I would not be able to clip them into place, so I first replaced the endcaps and then returned the tracks to their positions inside the dishwasher. Reattaching the upper rack is not difficult, but takes two people while I connected the left side, my assistant supported the rack on the right side.  I then connected the right side of the rack.  I slide the rack back and forth to macke sure that is worked smoothly.  We then loaded the dishwasher and washed our dishes as we had in the past.
May 27, 2008 | Dishwashers
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
Owen Barnes
