Question about Refrigerators
My Samsung side by side refrigerator is always leaking from the freezer side its either a SRS535NW or SRS536NP I think the outlet pipe might be blocked where is it and how do I check it
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Feb 01, 2010
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Water leaking from behind the drawer
in fresh food side or freezer. please describe.
Feb 25, 2014 | Samsung RS2578BB Side by Side Refrigerator
Daewoo side by side freezer leaking even though water turned off also icing up at bottom of freezer
Probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
From inside the freezer, I removed the lower back panel and thawed the ice build up on the drainage tray below the defrost heating element, leading to the pipe outside. The puddles of water that was appearing every defrost cycle have now stopped - permanently I hope. Hope this helps you
Aug 30, 2012 | Daewoo Refrigerators
Freezer leaking water even though water turned off
Is the water leaking from the door, onto the floor in front. If so, probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
Jun 04, 2012 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
I have a Samsung Refrigerator SRS535NW it has water leaking from the front freezer side and there is ice build up on the bottom in front of the door.
read this. it might be of help http://techie-doc.blogspot.com/2010/09/fixing-refrigerator-problem-frosting-in.html
Sep 16, 2010 | Samsung Refrigerators
The drainage hole is blocked. I clean it out with pipe cleaners etc. but I think the blockage is further down the pipe and out of reach. After cleaning my fridge lasts a couple of weeks then starts leaking...
try a flexible curtain/net wire to rod from top to bottom. and check that the outlet at rear of unit above the black compressor to the tray is unobstructed..
Dec 17, 2009 | LG LRTC19314ST Top Freezer Refrigerator
Samsung fridge model srs535nw service manual
Behind the white plastic section at the back of your freezer (4-6 screws to remove) there is a drain hole at the bottom. This will be frozen and prevent water from defrost from draining away - we have exactly the same problem. defrost the freezer and ensure this drain is no -longer frozen. I used hairdryer and warm water to clear. You may have a secondary problem of defrost cycle going wrong - the most common replaced part is R1098 or something like that a defrost sensor which is easy to replace by removing the top rear plastic section - 3-4 screws to remove and it simply pulls out as it is lightly clipped in. I was worried about breaking it but it came out with a bit of a tug. The defrost heating element is another part which can pack in. I'd replace the other part first and see how it goes.
Oct 06, 2009 | Samsung Refrigerators
WATER LEAKING FROM THE FREEZER INTO REFRIGIRATOR
Remove back wall from the inside of the freezer. Some models you have to remove the floor first, others you don't. There will probably be a lot of ice so have plenty of towels and hot water ready. It may take quite a while to get the ice to melt completely, but in my experience it is ALWAYS ice. Just keep refilling the pan with super hot water, and poke into the drain hole with a cable tie or pipe cleaner. When the water feels like it has gone cold, wipe it up with a towel, and refill the pan with hot water.
Jul 27, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Is there any water problems in burtonsville i thougt the pipe broke.
If it is like my Kenmore, the water tube connection at the lower edge of the freezer door hinge line, may have come loosened by opening and closing the door. That tube provides the water source for the in-door chilled water outlet. Just tighten the connections.
Jun 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
557 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
