Question about Dell Wireless 2350 Router
Cannot renew IP address on some PCs, each day it's a different PC in my house. This started happening a couple weeks ago.
  • 742 Answers
It is a router's default behavior to lock some IPs to a particular PC which are usually using it on the network. It is a leasing feature. Example, if your PC is using 192.168.0.125, and your IP range in your router is 192.168.0.100 - 255, every time you connect, though you are alone in the network and no other PCs are connected, still your router will lease 192.168.0.125 to you unless otherwise you disable this leasing feature in your router's admin interface. Renewing IP from the computer side do not alter the router's leasing policy. So right clicking on the network icon and selecting Renew IP won't help. What you need to alter is your router's IP leasing behavior.
Posted on Feb 02, 2010
EEE PC, Win XP, TCP/IP and DCHP does not work, cannot renew IP address.
flush and renew your ip address via this commands:
*click the start menu*select "run"*type "cmd"*press enter*you will have a black screen*type ipconfig/release*then it will release your current ip address*type ipconfig/renew to renew the ip address then you're good to go.
Dec 27, 2011 | Computers & Internet
Release ip address. I want to be seen on the internet with a different IP address. When I plug the cable modem directly into my computer I can release and renew and get a new IP with the network card, this...
The easiest way to release and renew your IP with a router that doesn't have that feature is to unplug the modem (not the router) for a few minutes - overnight while your sleeping to be sure.
May 23, 2011 | U.S. Robotics MAXg USR5461 Router
It does not make much sense. But it seems the WAP610N has a limit on concurrent connections. We just started to use this device in a small office network. There are about 15 laptops on wireless...
Two possibilities:
1. the router is configured to hand-out IP-addresses in a limited range, e.g., 192.168.1.100 to 192.168.1.110, namely 11 different IP-addresses. When the 12th computer asks for an IP-address, there is none available. Remedy: configure the router to use a larger range of IP-addresses.
2. when an IP-address is handed-out, attached is a 'TTL' ("time to live") value, indicating how long the IP-address remains valid, e.g., 10 minutes or 100 minutes or 1 day or 1 week. If the TTL is too large, then each computer "hogs" the IP-address (even after being shut-off in mid-afternoon).
Remedy: configure the router to use a shorter TTL. Don't worry: when a TTL value drops to 50% of its original value, on a specific computer, the computer will "renew" the lease.
Mar 18, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
My belkin router will not recognize the LAN connection of three PC. It will accept my laptop using the same Ethernet cables. I have recycled the router and reset my network. Still no connection. We had a...
Did you try direct wiring the other pcs to see if they will connect separately? If they won't then check the network settings on each pc that won't connect. Make sure that the gateway address is the same ip address as the router is.
Did it work before the outage, all of them at once? If so go to the Command Prompt (RUN, type in cmd, enter and a small window will pop up), and where the cursor is blinking type in - ipconfig - (some win versions use winipcfg) , hit ENTER. That will tell you what address are set to. It should say 192.168.xxx.xxx.
Type in - ipconfig /release - ENTER. That will reset the addresses which should now all be zeros.
Now type in - ipconfig /renew - (make sure you have the blank space between the g and the /). This should give you the 192.168.xxx.xxx address for IP if your network settings are set correctly under Network Connections- Properties-TCP/IP
Sometimes under outages you need to reset both the modem, the router and the pcs to acquire the new addresses.
Feb 22, 2011 | Belkin Computers & Internet
I can't get an internet connection thru the router, it says that there is a connection but as soon as I click on IE the connection is lost. The IE does work when its directly connected, this only started...
  1. Release and renew your IP address
  2. Click the Start menu button on the Windows taskbar.
  3. Click Run... on this menu.
  4. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  5. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  6. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  7. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
Also, make sure you are typing in the correct encryption key.
Dec 13, 2010 | Linksys Computers & Internet
Hi, previously all the 30 pc's in my office connect to the D- link switch and having no problem access the internet. yesterday, i changed my ISP and also the new router using 1 fix IP but all the pc's...
Your new isp probably has different dns addresses. Configure your dhcp to assign the new dns addresses. you can refresh the pcs by typing "ipconfig /renew" at the command prompt and your PCs will have the new dns addresses.
Hope that helps...
Oct 25, 2010 | Computers & Internet
Wireless connection - can not renew the IP address
Here's what you can do Sometimes you can simply right-click the computer icon in the task bar near the clock of your XP desktop (If this icon is present). This will go through a process of resetting your IP address.
But if you do not have this option, you can go to START>RUN and type cmd. At the command line type ipconfig /release (or winipcfg /release in earlier versions of Windows). Then hit ENTER. Next, type ipconfig /renew and you should get a new IP address from the router.
If this doesn't work, renew the IP address. You will have to nullify the IP address on the PC, then shut the computer down. Next, unplug the cable modem for a couple of minutes, then plug it back in again. Once all of the modem lights are green, power up the PC again. It should automatically renew its IP at boot.
Unplug the router, then plug it back in AFTER you plug in the modem, but before you power up the PC. The router will need to supply the PC with a new IP address. Good luck, hope this helps or gives you something to try.
Apr 11, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
What's an IP address?
internet provider address. ring your provider and they will sort it
May 24, 2009 | Acer Aspire One PC Notebook
Cant IP Address
press F11 when turning on your PC
Jan 30, 2009 | Microsoft Windows XP Home Edition
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
Oct 28, 2008 | Gateway Computers & Internet
Dell Wireless 2350 Router Logo
181 people viewed this question
Alun Cox
