The washing machine keeps blinking sud what does this mean? It won't finish the cycle.. it is a kenmore front loader HE 5t
  • Washing Mach... Master
  • 8,220 Answers
Either you have too much of the correct detergent in there or the wrong detergent in there. Here are a few of the errors:
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Posted on Feb 01, 2010
    Problem Solver:
  • 16 Answers
It will post a sud error if it cant drain properly. Either the wrong detergent!, or the pump is clogged. Both will cause this. Drain as much water from the machine as possible. Sometimes I use a towel draped over the machine to a bucket on the floor, after you got as much water out by hand. The towel creates a wicking/siphon action. More than likely though you have to remove the bottom panel and clean the filter or the pump.
Posted on Aug 30, 2012
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
HE2 Plus blinks F-11
Look for the technical brochure. Mine was on the lower kick panel taped inside. I would not take off the back panel first. Maybe the top or the lower front if it is a front loader. It tells you how to do diagnostics and what the codes mean.
Jul 22, 2009 | Kenmore HE2 Plus Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmoore wont spin front end loader
won't spin on the spin cycle it just has a grinding sound
Sep 10, 2008 | Kenmore Elite 45986 Front Load Washer
HE2 front loader error code
According to the HE2 Tech Service manual, it means "Suds Lock (Overdose of detergent detected during the wash cycle).
Aug 29, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
713 people viewed this question
Top Washing Machines Experts
