Hello, the switch went out on my LAT2600AAE washer. I'm trying to find a new switch and instructions on how to get to it to replace it. Thanks Much! Stephen
  • 129 Answers
Very easy to repair call 1-800-457-3104
Posted on Feb 02, 2010
FISHER PAYKEL WASHER GWL11 WONT FILL TANK
Check your diverter valve is in right and working.
Energized valve, water goes over bowl.
Non Energized valve water goes down the drain.
Feb 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
I can't get the cover off of my magic chef washer to change the lid assembly. It seems to be very different from the other instructional videos I've watched. thanks Brad
Hello Brad,
On that washer to access the lid switch the top come um from the catinet to replace the lid switch. To open and raise the top simply place a putty in the seam between the front of the top and cabinet about a 1/2 to 1 inch in from the corners and depress clips that hold top to cabinet then once they are depressed in lifr up the top
Gene
Aug 17, 2011 | Magic Chef CAV2000AWW Top Load Washer
Hello My washer filled up with water and quit.. Is there a reset button?
if the washer just filled up with water and stopped most likely it is the lid switch that has went bad try to see if the washer lid switch still makes a clicking sound if not replace the lid switch the switch is actually what actuates the motor to start to agitate if there is no presence of the two points connecting it does not start the cycle another way as a temporary repair till you get a new switch is to take a jumper wire and connect between the plug position 1 and position 3 this causes the switch to be by passed so that you may finish you clothes if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 16, 2011 | Admiral Washing Machines
Washer wont spin. It went thru the whole wash cycle, but now it won't spin, and there is no error code. It comes on and the time counts down, but it doesn't spin.
Hello,Hi, If it doesnt spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Hello, I have a frigidaire washer. I loaded it up and started it - the water went in. But after that, it just stopped. I tried it again, tried different cycles, still doesn,t work. The Start light is...
Well I'm not an expert but I have had problems in the past but it was with my top loader washer. Sounds like it could be a number of things: could be the transmission, or could be a switch or an electrical problem (thats the problem with these new digital washers/dryers!). You will definitely have to call a technician unless you can get a manual and try to fix it yourself. Mine is a year old and I purchased some extra insurance for it, like a year or 2 worth when I bought my washer & dryer new. If your washer is less than a year old you can probably get the manufacturer to fix it for free! Good luck!
May 15, 2010 | Frigidaire GLTF1670A Front Load Washer
Maytag LAT2600AAE with agitator that pulled out of transmission
You can find an exploded view at www.appliancepartspros.com
Hopefully that will help.
Mar 07, 2010 | Whirlpool LSB6200PQ Top Load Washer
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
Disassembly of washer agitator
With the palm of your hand, bang the very top section of the agitator, there are no screws, it is just a firm push-fit.
Do it with the agitator locked in the tub.
Oct 14, 2017 | Maytag Washing Machines
Kenmoore 22442 Washer will not drain or spin
I'm having the same problem with mine. Did you replace the lid switch or timer?
Jun 11, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
