Question about Ruud Heating & Cooling
On verry cold nights the aux. heat will not come in. The aux. heat can be turned on manualy
  • James Stopp
    James Stopp May 11, 2010
    Do you mean you have to turn it to emergency heat or turn down heat. rus
  • 334 Answers
There is a malfunction with the outdoor temp sensor on the heatpump.
You will likely have to replace the sensor.
If the strips are coming on in defrost and manually, then you know the relays, heat sequencers and other controls are operating. there apearently is no signal telling the system that the outdoor temp is to low for the HP to operate efficiently.
Posted on Feb 02, 2010
Why does aux heat come on when not set for aux heat
The "Aux Heat" setting on many heat pumps is electric heat. The electric heat will turn on when the outdoor temperature is too low to extract heat from the air. This can cause a significant increase in your electric bill if it remains too cold for the heat pump to work as designed. This is why heat pumps are used more in moderate climates as opposed to those that experience much colder temperatures. The electric heat also turns on during the "defrost cycle". Both of these conditions are normal. The video below may help you understand a little better.
Dec 08, 2015 | Heating & Cooling
I AM GETTING COLD AIR AT NIGHT TIME. IF I PUT THEMOSTAT HIGHER THE AIR GETS COLDER . THIS HAPPENS EVERY NIGHT AROUN8:00 AND STAYS LIKE THIS FOR HOURS. JUST FILTER CHANGE
Is this Heat pump? if so what are the outside temperatures?
If heat pump there are controls connected to the thermostat that may at about 40f stop the heat pump, and switch to aux or emergency heat. If the aux is Electrical heating coil, you may not have power to the relay for the Electrical coil. If the Aux heat is gas, there is a problem with the controls. If none of the above are true, I would suggest your programable thermostat is calling for a lower temperatue at 8pm. I know termostats are not fun to program. It will take you some time to learn how, if you have the owner's manual. otherwise find the manual, learn, find a friend or family menber that knows how. Last resort change thermostat to non programable or have heating tec come by and help. Make sure everything else is ok in the heater.
Feb 27, 2015 | Filter Heating & Cooling
Blows heat until it matches the thermostat then it just stays on and keeps blowing semi cold air. It just maintains the temp but will run all day and night. It is a heat pump with emer/aux heat. If I...
Download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Feb 01, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I have a Zenith SM2067BT TV set. When I turn on the TV, it is evidently turned to the wrong channel. It comes on channel 2 instead of three. When I try to change the channel to 3,it reads aux or aux seq. I...
you must be on a box, put your tv on channel 2or3 then with the control for the bx channel up-down if not then just do channel up-down manualy
Feb 14, 2010 | Zenith B25A02Z TV
On my thermostat which is a white-rodgers the flame symbol is flashing the heat is set to 68 but it stays on 66. I have a split unit Ruud. The problem happens at night when it is cold.
Is this a heat pump system? If so I would recommend switching the thermostat to aux. or emegency heat at night when it is cold outside. The heat pump will not keep up when the outside temperatures are real cold.
Jan 15, 2010 | Heating & Cooling
Very cold outside should we swithc to aux heat to be more effice
I recommend running the heat pump even in the cold weather. If you like you could turn to EM heat around 10 degrees, but you do not have to. The newer heat pumps seem to work better than the old ones did in the colder weather.
Jan 04, 2010 | Goodman CLJ30AR32 Air Conditioner
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
Jan 03, 2010 | Goodman PHKJ048-1 Air Conditioner
Heater running continuously
Sounds like you have a problem with your heat pump. Your aux heat is a electric coil. how old is the unit when was the last time it was serviced? How cold is it out side?
Jan 15, 2009 | Honeywell Programmable Thermostat Heater
My Aux heat seems to run all the time.
Is it cold enough in your area to lock out the heat pump?If the heat pump isnt operating correctly the aux heat will come on then too.
Jan 04, 2009 | Goodman PHKJ048-1 Air Conditioner
1992 honda accord ex 4 door heater not blowing
You may have a clogged heater core, leaking heating cores still provide heat.
Dec 04, 2008 | 1992 Honda Accord
Heating & Cooling Logo
60 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
