Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
The color is way off on the tv. It also looks curved, like if there are words on the tv they go up at an angle toward the edges of the tv. When you try to align the color on the tv you can get the center to align on all but the blue but when you go to multipoint alignment you cannot move the outer points. The tv looks like it should be in 3d. I would like to try to fix it by myself.
  • Philips Master
  • 3,459 Answers
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
The color is way off on the tv. - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 03, 2010
In what direction should the plastic, 8-blade, aftermarket replacement for the metallic OEM fan turn when installed?
Find me helpful, the feathered edge is always the trailing edge. Find my other posts to your same question helpful, The B side, thick edge goes towards the engine on your belt-driven ford ranger fan. This is not rocket science. in-direction-plastic-8-blade-u40lsvyytnuesyuv3fbafhtd-1-0.gifa picture just 4u.
Jan 01, 2015 | 1987 Ford Ranger
My camera says my memory card is write protected. What does that mean and how do I turn it off?
Remove you SD card from its slot and look at the card. With the card's label facing you and the angled corner to the top right, look on the left edge of the card and you will see a very small slide switch and the label will probably have the word "lock" printed on it. Slide the switch upward toward the top edge of the card and the memory will work. This is called a write protect feature and it is designed to prevent you from accidentally erasing your important pictures.
Aug 07, 2013 | Nikon Coolpix L310 Digital Camera Black
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Green convergance wont adjust, bowed screen
Green really shouldn't be adjusted, you adjust red and blue to the green. When a color is bowed that indicates that a part or two are bad, probably the convergence output IC's and possibly a fuse or fusible resister. You may need a tech to come adjust it for you because after replacing IC's the adjustments should be done in the servicers menus not just in the consumers menus.
Mar 13, 2009 | RCA P52937 52" Rear Projection Television
Hi, have a 50 inch rear projection Mitsubishi. The problem is that the picture is curved and some of the words around the edges are doubled. Its most noticeable when watching sports because the score board...
power transistors in the convergence circuits on this series TV go bad after several years, making the wavy lines around the edge of the screen and 'doubling' of the edges of the text in varied colors which do not converge. Professional repair is required unless you are brave enough to tackle the project yourself and follow some rather simple instructions, buy a few tools from Radio Shack, and save yourself about $500 bucks...which I did on my own 42" Panasonic rear projection set.
Feb 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
212 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
