Question about Amana ALW480DA Top Load Washer
Machine fills up only half way....water eners very slow....afta machine stops, I get a PF 6 reading
    Brigadier General:
  • 4,088 Answers
Try removing each inlet hose in turn and check for water flow from each hose. If seem slow, try reversing that hose to back-flow the inlet filter screen which should remove loose debris, but won't affect any hard water deposits (soak the screen end in white vinegar and hot water for an hour or so). If both hoses flow well, check the entry holes in the machine for plugged screens. If all else fails, replace the twin inlet solenoids. Hope this helps!
Posted on Feb 01, 2010
Washing machine stopped working. The lights come on but water wont start filling
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 25, 2011 | Washing Machines
Water stops flowing in the machine
heatman101
Apr 13, 2011 | LG Washing Machines
Press the start button,you hear a click,water runs for a second or so, water stops,that's it. Nothing else happens. Any suggestions. Thank you,S.Nielson
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Feb 19, 2011 | Frigidaire Washing Machines
My machince is not filling up a the way it just stops
heatman101
Sep 18, 2010 | Washing Machines
No water flowing into drum, water supply is fine, just humms
My Samsung washer was not filling with water after cleaning the debris filter. All I did to fix it was to dump a half gallon of water into the tumbler, then I ran the beginning of the rinse cycle and it worked. It seems like the pump needed to be primed.
Sep 16, 2010 | Samsung WF337AA Front Load Washer
Washing machine won't stop filling .water won't shut off
That is kind of the opposite problem of these tips...the solenoid valve has dirt in it...
Normal 0 MicrosoftInternetExplorer4
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 10, 2010 | GE WJSR2070B Top Load Washer
My Maytag LAT9400 top loading washer has stopped allowing hot water to enter the tub, only cold water works. What might be wrong?
heatman101
Sep 06, 2010 | Maytag Washing Machines
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Will not stop filling with water, overflows
Yeah, it's kinda the opposite of these tips... you got dirt in the solenoid valve and it won't shut off...
heatman101
Sep 02, 2010 | Washing Machines
Coffee drips slowly and water doesn't drain completly from filling chamber. had machine for about 6 months and was happy until today.All I hear is a humming, a slow drip of half a cup and then it shuts off...
mcdevito75 here, Your coffee maker most likely needs cleaning, Water will leave deposits in the brewings ports over time and will have to be cleaned out, Follow your owners manual on cleaning your coffee maker.
Jun 17, 2010 | Keurig B100 Coffee Maker
Amana ALW480DA Top Load Washer Logo
100 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
