Question about HP CopyJet All-In-One InkJet Printer
I need to order the power supply adapter kit for the HP F300
  • HP Master
  • 685 Answers
Ebay is a good place to start if you want to get it cheap but there is alot of places online you can check
Posted on Feb 02, 2010
HP Deskjet F300
When you click 'print' on your computer, change the printer-settings to "double-sided" or "print on both sides", and then click OK. The printer will do the rest.
Jan 07, 2014 | HP Deskjet F300 series
I have a HP printer on the front it sayd HP Deskjet F380 but on the back it had f300 all in one series with the model number beingQ8130A. i need a psu for this printer can u help?
HP Deskjet F380 falls under the F300 all in one series of HP Printers.
You need to contact your nearest HP dealer to buy a PSU for your printer. Or else contact HP Technical Support over phone for more info.
Feb 21, 2011 | HP Deskjet F300 series
The 750 printer has has a low voltage plug point on it what type of power pack is this and whats the voltage where can it be obtained? we have the printer but we will be needing the power supply to...
You can buy the required adapter from any local printer repair shop.This printers adapter is easily available with them. You can also order this adapter from online site. to see how the adapter exactly looks for your printer.please click on the link below :--- http://www.ioffer.com/i/2880-power-supply-ADAPTER-HP-PSC-720-500-280-printer-104058987 ----------- Also if you require any other part for your printer then click on the another link below:-- http://www.partshere.com/hppartslist/hpparts.asp?part=c8424a --------- also this link sells the adapter http://www.nevershopping.com/ns017296.html ------------ Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Jul 29, 2010 | HP PSC 750 All-In-One InkJet Printer
Need power supply for Hp 336044-B21 KVM Switch. (DVE Switching Power Supply, Model DSO-142L) in the last two month I lost three same switches with the same problem - power supplies...
There are a few things that you can do. First; try to go online to HewlettPackard.com and locate the power supply. Second;go online to ebay and search for the power supply. Last;locate a Batteries R Us store in your city. They have a huge supply of batteries and power adapters. If you do not find a HP adapter the store person can help you find one that is complimentary to your HP adapter.
May 29, 2009 | HP 336044-B21 8-port KVM Switch
My scanner on my f300 printer won't scan
Hello!
Please check the "Troubleshooting: part of the manual. Hopefully, it will help!
https://manualsbrain.com/en/manuals/1173918/?page=43
Aug 09, 2017 | HP Office Equipment & Supplies
Error 50.6 in hp laserjet 9500hdn
  • HP II/III series most likely cause is the ac power module is defective. Order the HP II/III Service 50 Error Repair Kit. If the quartz fuser lamp is burned out, order the replacement fuser on specials page. Slight possibility of loose connector on DC controller. See tweaking page DC controller could also be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order the HP 4 Service 50 Error Repair Kit. Could also be a failure of the power supply.
  • HP 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating element.
  • All other printers most likely cause is burned out quartz lamp. In rare instances the ac power supply has failed. Even rarer, the DC controller is defective
Jan 22, 2009 | Office Equipment & Supplies
BUSH IDLCD27TV006
http://www.chsinteractive.co.uk/pdf_data/KT02.pdf
Order Code….. KT02
POWER SUPPLY REPAIR KIT
BUSH MAXIM 1157 1154 Medion
Goodmans (Standard) 04TA069I 05TA71B 05TA071C
A standard power supply repair kit for faults attributed to the standby +5v rail.
BUSH IDLCD27TV006.
MAXIM 1154, 1157.
MEDION MD30112.
GOODMANS IDLCD27TV006.
The numbers off the boards will read: 04TA069I 26” 27” 30” 32”
& 05TA71B, 05TA071C.
LCD TV POWER SUPPLY PROFILO-TELRA.
Please check the primary of TR20 before fitting the kit.
Primary windings should read approx 2.700mH / 4.00 Ohm.
We recommend all kits are fitted by qualified engineers
We accept no responsibility for loss, injury or damage caused by your use of this kit as a successful repair
depends on your own skill and fault finding ability.
Circuit Reference
Loc Description
F300 T3.15A FUSE
IC21 FSD200
IC30 ICE1QS01
D315 12V ZENER
D318 2V4 ZENER
Q300 BC337
Q302 BC848C SMD
D325 1N4007
C213 33UF
C322 47UF
C356 47UF
C330 1000UF
LINK (IF NEEDED)
Oct 31, 2008 | Televison & Video
Installing f300 all-in-one series printer, to computer w/windows vista home premium[32]
Go here to and click on your specific model, then click on 'Software & Driver downloads', then your Operating System, and you should now be able to download the correct driver package for your printer. I hope that helps. Bundled software with printers and other devices is often out-of-date.
Dec 06, 2007 | Office Equipment & Supplies
Seeker5211
Seeker5211
