Question about Panasonic DMR-ES40V DVD-Video Recorder
How do i record shows longer than 30min's ?
Using..."Imitation" DVD-R 8x 2 hours video 4.7 GB data ... How do i record a program that's longer than 30min's on this disc? I don't know what to do...and the disc itself reads on the front "2 hours video 4.7 GB data"....I've only been able to record a 30 min program. My daughter lost the manual and my knowledge of electronics is very limited. Thank you for your help it's greatly appreciated. connie jo simpson usagranny4@yahoo.com
Change your record mode to ep.
Posted on Jun 11, 2008
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
What is the recording time for philips dvdr3380/05 dvd recorder
Depends on the media you use. Normally a DVD can hold 4 GB of data and depending on the compression, format you choose it should hold some 2 to 4 hours of video-audio.
Mar 04, 2011 | Philips DVDR3380/05 DVD Recorder
I have always been using Nero burn software with my LG GSA-2166D DVD RW. Now I bought Nero Multimedia Suite 10. No any writing process has been successful. I have since yesterday spoiled 10 DVD's....
speed of source data is too slow = the hard disk cannot deliver the data fast enough and the burning process stops; this is a sign of a severely fragmented file system and very charged background processes: defragment your hard disk, stop using other programs when burning a disk and use 8X as a recording speed.
 Track Following Error = the laser head in the burner is no longer capable of following the track it has itself burned - the lens is dirty, clean it.
Jun 12, 2010 | LG GSA-2166D DVD RW Dual Layer Burner
Won't work with the same kind of discs i've used before
I not sure as to which type of Discs that you are refering to (ie DVD+R or DVD+RW). This player will only recognize 4x (max) DVD+RW and 8x (max) DVR+R discs. If the DVD+R Disc is 16x, the DVD recorder will not recognize it once you start to record. The player will read the blank Disc and give the impression that it will record on it. I have noticed that when a 16x speed Disc is in the Drive, The recordable hours for the disc seems to double. The normal 6 Hour recording length comes up as 12 Hours when you hit the info button. Since the 8x Speed (max) discs are not available any longer, I found it best to use the DVD+RW 4x Discs and make it compatible. I then copy the compatible DVD+RW disc to a 16X DVD+R disc using my computer DVD burner. The DVD+RW disc can then be erased so that it can be reused.
Nov 23, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but...
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Mar 04, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Sony RDR-GX355
There can be faults in writer which causes data loss during the recording....the disc is also very important....Try reducing your writing Speed ( For CD-20x , DVD-8x need not to be the same)...
May 10, 2008 | Televison & Video
Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Dec 24, 2007 | Emerson EWR10D4 DVD Recorder
Programming errors
Several things to check 1) Your time - set it manually and remove the automatic time set 2) Try manually recording even a few min of anything (just put on channel to record, press DVD button and DVD Record button) - does it give you an error message on that disk? If so it might be because you are using 16x and machine sometimes gets messed up and won't record on those speed disks - same with +R sometimes does this - try recording on 8x -R ones. Hopefully this helps - if not try unplugging unit from wallsocket and leave off about 30min then try setting program again etc (plus current local time) and use a new disk and see if problem still occurs - sometimes just unplugging it "resets" everything and then starts working again.
Jan 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Televison & Video Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
