Question about Canon LaserClass LC 8500 Plain Paper Fax
Ring Cont on Canon LC 8500
How do we change the Ring Count from one ring to three rings?
  • 59 Answers
Lift up the 2 keyboard panels and press data registration and press set. scroll down using down arrow to RX settings and press set scroll down to turn ringer on and set the ring count to 3 and set and press stop a few times.
Posted on Feb 20, 2008
We have a TGF370 and I've lost the manual. How do I change the # of rings before answering picks up?
#211 is the program code.
Lift handset press menu#211
Use the up and down arrow till you see ring count
You can make the ring count 2 - 7 rings before answering.
Then press SAVE and OFF
Sep 17, 2017 | Lands Phones
I have 2000 ram 1500 4WD v8 5.9l auto. Need to change refer ring and pinion. Dose the teeth of ring and pinion should be same ront and refer?
NO--- Check Gear Ratio On Tag Or Tube--Front and Rear Are Not The Same. Or Count Teeth On Pinion And Ring Gear--Divide Pinion Number Into Ring Gear Number For Ratio.
Feb 17, 2015 | 2000 Dodge Ram 1500 Truck
How do I set my canon MP830 fax/printer to ring a certain amount of times?
  1. Press the Menu Button
  2. Use the keys to select Device Settings Press OK
  3. Use the up and down arrows to select Fax Settings Press OK
  4. Scroll down to Incoming Ring Press Ok
  5. Set Ring Count
Jun 22, 2011 | Canon MP830 All-In-One Printer
Can I change the ring count for voice mail to three instead of 2 or 4 OR6
Sorry you cannot set ring count for voice mail to 3.
It has settings to set for 2,4 and 6.
Thanx
Jul 04, 2010 | Uniden TRU8885 Digital Answering Machine
Change number of rings before answering
Change the ring count on the fax when the receive mode is set to Fax/Tel or FaxOnly modes. Change the ring count on your answering machine when it is connected to the fax and the receive mode is set [Ans mc connect] (Answering Machine Mode).
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow button to select [Maintenance/settings], then press <OK>.
  4. Press the left or right arrow to select [Device settings], then press <OK>.
  5. Press the up or down arrow to select [FAX settings] (item <1>), then press <OK>.
6. Press the up or down arrow to select [RX settings] (item <3>),
then press <OK>.
7. Press the up or down arrow to select [Incoming ring], then press
<OK>.
8. Press the up or down arrow to select [ON], then press <OK>.
Note: The default setting is [OFF]
    1. A window will appear displaying the number of rings before the machine will answer. Press the up or down arrow to select the number of rings (from 1 to 30 rings).
    2. Press <OK> to set the number of rings.
9. Press the <Stop/Reset> repeatedly to return to Fax standby
mode.
I hope this helps.
Apr 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I want to extend the number of ring tones before the fax answers on a Canon MF-4140 multi function Please
u press the man's head and go to fax settings with the arrow,press ok and go to rx settings,press ok,go to incoming ring,ok,it should be on,press ok,says ring count,press ok,and press the nr of rings u want!Good luck!
Mar 27, 2010 | Canon Office Equipment & Supplies
AFTER ABOUT TWO RINGS, IT GOES INTO FAX.
set the ring count higher and change mode to fax/tel
Aug 03, 2009 | Canon FAX-JX200
How do I set the phone to ring 5 times before going over to fax?
Press Funktion,Dataregistraion,press ok,Usersettings must be on the display,scroll with the arrows until you get RX settings press ok,scroll with the arrows until you see "incomming ring" press ok and change to yes if it was set for no.The next step it will ask you for ring count press ok and set it for 5 press ok again.
Mar 02, 2009 | Canon L220 Plain Paper Laser Fax
Need to change my ring tone in Fax Canon laser class 2050 G3
Press dataregestration,use the arrow to go to rx settings,select rx settings with the set button,go to incoming ring,select and switch it to on,and then cange the ring count to the amount of rings you desire.
Jan 06, 2009 | Office Equipment & Supplies
Fax\phone line
Here's how to change the ring count...and I'm also providing the link for support and troubleshooting your specific machine on Canon's website...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
To Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [INCOMING RING] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [ON] then press <OK>.
5. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
Hope this worked for you!
MaggieB
Feb 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon LaserClass LC 8500 Plain Paper Fax Logo
118 people viewed this question
old marine
old marine
