Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Can't tow my John Deere 2010. Clutch / PTO locked?
I have a John Deere 2010 Diesel that has the clutch / PTO locked for winter. I can't tow it out of the garage for service. How do I disengage This ''winter'' shut off swith for the clutch so the tractor can move? I think I accidentally hit the PTO drive lever while the Tractor engine was off. I tried to put the shifter in ''Tow'' position and pushed in the clutch, but the rear tires are still locked up. All of the linkages on the Dash do not seem to help.
  • craig_winter Feb 02, 2010
    It is a Model "R" Diesel. I would have to check later for the exact serial number but I believe it begins with a "5"
    I have Tried putting the shift lever in "Tow" position and also placing the shift lever in between gears while pushing in on the clutch. I have not tried to hit or add heat to the break areas yet. The temp is only in the teens, so I have not tried to start it. Not sure where the emergency break lever is to give that a try. The Tractor started up with a lot of smoke about a year ago, but I tried to start it a month or so ago with no success. (low battery and bad glow plugs).
    The reason I am having it towed is for someone to look at the shifter linkages and transmisssion. I only have the odd gears on this 8 speed when the tractor runs. none of the even gears seem to want to work or stay engaged. Inside the transmission looks great. No metal shavings or broken gear teeth. It was very clean inside. I figures the adjustment is out on the shifter linkages or the Syncro clutches may be bad.
    President:
  • 1,627 Answers
I need to know the exact model of your tractor,if it is a 2010 then the range lever being put in neutral should be all that is needed unless the brakes are stuck on,which does happen if it has set with the park brake on for extended periods of time.Let me know what the model is and what you have tried and i will get back to you on the repairs you need and how to carry them out.
Posted on Feb 01, 2010
  • danny herget
    danny herget Feb 02, 2010
    A model "r" is a tractor that was made well beyond my experience but i have some resources that i can try.Ignore all the suggestions i have given you because this tractor is old school and i was thinking new school.Give me a day or two and i will try to come up with a solution that you can use,be patient,i don't give up easily.
  • danny herget
    danny herget Feb 07, 2010
    Sorry it took so long to respond but i can not find any liturature on the model "r" so you may want to re ask the question to another expert,sorry.
John Deere GT-245 PTO clutch not coming off, bolt is off, the lower part of the clutch came off not the rest of it help how do I get the rest off I tried a puller
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 28, 2017 | John Deere Garden
JD 345 pto will not turn on.
What you need are wiring diagrams, not schematics, and you will have to inquire directly to John Deere.
Jul 20, 2016 | John Deere Garden
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
John deere stx 30 pto wont engage
Check your fuse or for a broken wire( or shorted)
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
John deere 997 z trak pto not working,changed pto switch not help
You may have a defective park brake switch or the pto clutch could need to be adjusted.Does the machine **** down when you try to engage the pto?If so also check the seat switch.To adjust the pto clutch you need a 9/16' wrench and tur all three lock nuts on the clutch a half turn at a time a retry the clutch,keep going until it will stay engaged.
Nov 08, 2009 | Garden
Pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Sep 18, 2009 | Garden
John deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
155 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
