Question about Denon AVR-589 Receiver
Denon AVR-589 and Coby speakers-No sound from SW
I have a Denon AVR-589 and Coby CSP96 5.1 speakers & subwoofer. I have run the Audyssey MultEQ Auto set-up but get no sound from the SW nor does the receiver recognize the SW- All speakers are recognized & sound to them is fine, but not the SW. I have the receiver connected to the SW with a monster standard THX subwoofer connector cable. I have gone through the manual multiple times, but can not figure out what I'm doing wrong.... Any suggetions?
VOTIT
  • 2071 Answers
SOURCE: trying to install my denon
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 20, 2008
  • 3 Answers
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
  • 92 Answers
SOURCE: AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
Posted on May 18, 2009
mlapres
  • 757 Answers
SOURCE: How do I reset my Denon avr-589?
Press the power button, and speaker a and speaker b simultaneously and hold until the display begins to flash then release speaker A and speaker B buttons. That resets the microprocessor.
Posted on Jan 02, 2010
SOURCE: subwoofer works in test mode on denon avr 790. but
I had the same problem. The system from the factory does not ship confgured for continuous subwoofer output. To fix this, do the following:
1. Enter the system menu.
2. Go to "Speaker Setup"
3. Select "Bass Setting"
4. Change the setting from "LFE" to "LFE+Main"
That should do it... You can also see this information in the "Bass Settings" section of the product manual on page 26.
Posted on May 04, 2010
Denon instructions
I don't have this particular model but I have owned 2 Denon receivers and I suspect yours is similar. On my Denon there is a manual speaker set up with a test tone for each channel. This will allow you to boost or reduce the DB level of each speaker individually. I would do this while sitting where you do while watching TV. be sure:
1. The receiver is in surround sound mode to do this.
2. My receiver also came with a microphone that can be plugged into the receiver to allow automatic level set up through what Denon calls the "Audyssey" set up. The equalizer setting are also located in the "Audyssey" settings.
You might check your manual before you begin.
Sep 07, 2014 | Denon Avr-4802R-Av Receiver-7.1 Channel
AVR-1912 & no subwoofer
It sounds like the sub has an auto power mode, hence why it switches to red (off), so your system will not detect it. If there is any control to switch it on all the time do so and try it again. It must be green all the time during the test.
Jul 26, 2017 | Denon AVR-1912
My subwoofer input is not working!
Check that the front speakers are set as "small" in speaker setup menu and sub="yes". let me know what you get.
Jan 24, 2012 | Denon AVR-589 Receiver
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
Jan 18, 2011 | Denon AVR-589 Receiver
My Denon AVR 589 does not seem to send any signal to my sub, I have try another working sub and it does the same. I just notice this week that my sub was not working. I have check on the amp setting and...
Is there a switch on the back of the receiver that will switch the sub signal from digital to analog? And the same switch might be on the subwoofer itself.
Hope that helps if not just reply back.
Thanks
Dec 23, 2010 | Denon AVR-589 Receiver
I hv a Denon AVR 3805, i tried to set it up but after doing all the necessary, i found out that it was only running on 3 speakers (FL,FR & SW). I did connect the center speaker but the sound just...
SW means sub woofer, not necessary means center speaker in all receivers. Instead of setting 5ch stereo, if you have 3 speakers. try to set "3channel" or "simulated". If you own more than 3 speakers, you may refer to the userĀ“s manual to correctly wire them to get the full sound.
Sep 18, 2010 | Denon AVR-3805 Receiver
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
May 29, 2009 | Denon AVR-2308CI
No sound playing through microphone
The microphone included with this receiver is for audio adjustments only. That's the "Audyssey Laboratories' MultEQ® six-point auto setup and room calibration system". You cannot hear yourself speaking through the microphone.
Nov 26, 2008 | Denon AVR-1905 Receiver
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
Denon AVR-589 Receiver Logo
80 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
