When the phone rings the computer is bumped off att 2wire router
Wireless telephone causes 2wire router to drop off wireless computer ????
  • 70 Answers
The router and cordless phone might be working in the same 2.4ghz frequency, try to keep the phone as far from the router as possible. and change the w/l channel in phone or the router so as to reduce the interference.
Posted on Feb 02, 2010
Testimonial: "haven't checked further than they are on the same frequency. A great start, now how do you change one of them? I'll figure it out! Thank you much!"
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Cannot connect my dell laptop wirelessly, will connect with a wire and will connect wirelessly at the library. The old 2wire was ok but we replaced it with a new 2wire today. Have spent 3 hours with att...
Since you are able to connect using a hardwired connection and you're able to connect wirelessly at the library, that simply means that your computer and your internet browser are fine. where is your wireless computer and your wireless located? are there any possible wireless devices interfering with the wireless signal like chordless phones, cellphone, TVs, radios, microwave oven? are your walls in your house covered with metal plates coz that would really make the signal deteriorate. the settinngs on your wireless router may also need to be reconfigured and boost up the signal of the wireless router.if only i could remotely access your wireless router, I would really walk you thru on what to check on your wireless router
Jul 07, 2011 | 2wire (1000-000057-000) Modem
When i connect with the internet and my phone rings, the internet connection is interrupted and I cannot use the phone and internet at the same time. please helps
I'm goign to asume here that you have DSL by your problem. If I am incorrect then please let me know.
With that said, first you need to check that your dsl filters are correctly connected and functioning correctly. If you hear a static or fuzzy sound on the telephone even echo this will be the casue from a bad filter or non-existing filter.
A filter that is bad or missing will cause DSL to drop its connection. The telephone call will cause too much interruption with the dsl signal and causes the modem to drop the connection to reconnect with a more solid connection.
So what you need to do is check your filter by changing it as well as checking this problem that it happens on all phones not just one individual.
Please get back to me if you need more information or this does not help you.
Jan 27, 2011 | 2wire (2701HG-B) Wireless Router
My att 2 wire keeps flashing red on and off for dsl and then the green wireless light goes off and internet goes down. I get a msg that the broad band cannot connect. I have checked and double checked...
Hi
This is Neo . Check the Filters in the phone line if you have installed the filter . if there is no filters before the telephone , install a filter . Whether the phone line are connected properly and check the wall point where the connection from the DSL and telephones . Check the cords and try changing the RJ11 cords . RJ cors the phone thin cords .
NOTE : FILTERS SHOULD BE INSTALLED FOR TELEPHONES BUT NOT FOR 2 WIRE .
Nov 02, 2010 | 2wire 2700HG-B Router (2700HGB)
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting ADSL wireless modem router to COMCAST
unfortunately you can't because the 2wire is a dsl modem it has to use the phone line to connect to the internet, it would be different if it was just a router but since it is a modem it needs that connection to the phone line in order to work
Oct 15, 2008 | 2wire (1000-400108-001) Router
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
