Question about Whirlpool Duet GHW9150P Front Load Washer
Control panel has power going to circuit board but no lights no control
  • 129 Answers
Control board bad
Posted on Feb 02, 2010
I have the 60LN5400-UA I spoke with someone the other day and they suggested to order a power board. I am confused I have no red stand by light but I can see the lights through the back panel.
If the power indicator LED at its front panel is ON, then the power supply regulator section circuit board is OK. The fault should be with its digital main board itself. After power is switched ON, the poser regulator board supplies different voltages to different stage circuits inside. These voltages are controlled by the main system control IC, at its main digital board. Now it do not work, and why you can't power ON the set, either by remote control, or with the front panel control.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 01, 2016 | Televison & Video
Both washer and dryer (MDG5500A) dead except for drum lights.
I am afraid there is no breaker or fuse inside the machines that will cause the control panels to go dead. You can check your power to the boards at L1 and neutral. If you have the proper voltage here but controls are dead, you will have to replace the control boards.
I notice in your problem heading it stops at the word except. Except what?
Thanks/mike
Nov 18, 2007 | Maytag Neptune MAH5500B Front Load Washer
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Changed door switch and still its like the dryer has no electricty
The nicest problem would be that one side of the 220VAC power line is dead, possibly due to a bad circuit breaker. The drum light runs off one side of the line only, but everything else requires 240VAC (i.e., both legs of the line.) So, if you're really lucky, you could turn off the circuit breaker, turn it back on, and everything will work. If you've got a voltmeter handy you could also verify 120 VAC between each leg and neutral, and 240VAC between the two legs.
If your incoming power os OK, it's an electronic control (aka main circuit board, computer board) problem. The solution could be as simple (and cheap) as just reseating the connectors going to that board, or as simple (but expensive) as replacing the board.
Sep 14, 2012 | Kenmore Elite HE4 Electric Dryer
Dishwasher wont start no lights on machine
Check that there is power to the outlet. You can also acccess rear panel and check that the fuse is not blown. You can take a voltmeter and test the wires going from power supply to the main circuit board to see if there is power to the main board. If not, supply is bad, if there is power, then it is likely the main control panel is faulty. You can test power to and from the panel with an ohmmeter, test light, or voltmeter.
You can get parts, manual, and more at repairclinic.com or partselect.com
Nov 19, 2009 | Dishwashers
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool Duet GHW9150P Front Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
