Question about Oreck XL Ultra Bagged Upright Vacuum
Motor just hums
My oreck xl was clogged under the bottom so i took the bottom plate off and cleared the clog. Now the motor won't spin it just hums
  • 1 more comment
  • odellcv Feb 01, 2010
    It won't rotate by hand
    it won't turn by hand
  • odellcv Feb 02, 2010
    The motor was stuck. I gently turned the shaft with a pair of pliers and it was free. Thanks for your help.
    Sergeant:
    Champion:
  • 258 Answers
It still stuck try and rotate it by hand
Posted on Feb 01, 2010
  • jwtbagger Feb 02, 2010
    right on thanks man happy to help they get debris built up in the motor leave me a testomonial if u can
Oreck XL intellashield smells hot and smoky when operating. New bag and belt and no clogs. About a year old.
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Dec 17, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Nov 13, 2008 | Oreck XL2200 Bagged Upright Vacuum
ORECK VACCUM
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=747767
Generic problem for all Vacuums
ORECK VACCUM
Posted by FISHERMAN928 on Jul 06, 2008
Older Oreck XL, new belt, new bag, checked for clogs, does not pick up
as it used to, and, much harder to push, seems to grab or drag, why????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that may work. Depending on if you have the old style brushroll you can upgrade to a new style Oreck brushroll that has twice the brushes and will a work a lot smoother. Also, clean the bottom plate – get rid of any dust and dirt build up and then spray the bottom with silicone and let it dry after you have totally cleaned it. Always use Oreck genuine belts and to change the belt every 4 to 6 months for the best cleaning and store the extra Oreck belts in a Ziploc bag in the refrigerator, other wise if you have a new belt, gag, you have checked for clogs there is no reason why it should be hard to push, if the silicone does not work replace the bottom plate.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Jun 07, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Not sucking
You probable have a clog in the handle tube, or at the bottom, either by the brush or in the neck where the handle goes into. Unscrew that big black nut and pull the handle off of the bootom asm, then you can check it out and see where the clog is. Pull the bottom plate off to see if it is there where the dirt goes in.
Feb 17, 2008 | Vacuums
Oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Dec 28, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck Vacuum troubleshooting
That the bottom plate off, check for a clog in the inlet. If clear, then you probably have a clog in the handle tube. You will have to take the handle loose to clean it out. It may also need a new belt if you haven't changed it for a while, they stretch.
Nov 21, 2007 | Oreck XL2800 Bagged Upright Vacuum
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Sep 07, 2007 | Vacuums
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
88 people viewed this question
Top Oreck Vacuums Experts
Gerry Harvey
Gerry Harvey
john h
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
