Question about Ovens
I am after a manual on a technika ghe06t stove, thanx anne
Looking for a manual for a lofra 80cm freestanding oven model number LEF8GG3SS
Try contact Technika:
  • Sales
  • Phone: +61 (3) 9948 4577
  • Fax: +61 (3) 9948 4555
  • Email: sales@technika.com.au
  • Customer Care: 1800 649 969
  • Service
  • Phone: +61 (3) 9948 4545
  • Fax: +61 (3) 9948 4546
  • Email: service@technika.com.au
  • Customer Care: 1800 333 244
  • Spare Parts
  • Phone: +61 (3) 9948 4548
  • Email: spares@technika.com.au
Front Page Technika
Apr 07, 2015 | Ovens
Ovens technika B90MTDISS instruction manual
www.technika.com.au/contact
Jun 13, 2014 | Ovens
Technika oven manual - mod B50STIP/1
I have a Technika B50 STIP /1 Oven and the Oven Function Selections have warn off. I mostly use the conventional cooking ) at 7.00 oclock on the dial) I cannot remember what is on the dial at 5.00 oclock? as it has worn away.
Help please
Liz
Aug 05, 2012 | Ovens
I need the Instruction manual for the "Westinghouse GXL 650SNG Gas Wall Oven"please, the people we bought the house from did not leave it. Thank you Regards Mary-Anne
Hi Mary Anne.
Here the manual available for immediate download.
If the link above does not open, click right mouse button on the link and choose 'save link as'.
Here also parts and diagrams.
Regards.
Ginko
Jan 01, 2012 | Ovens
I have a westinghouse GOL472SNG and the glass is broken I was woundering if you could tell me how to remove the door?Thanx
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 18, 2011 | Ovens
Self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Mar 07, 2009 | Kenmore Ovens
Hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Electric surge turned off the clock,oven but the stove top works
The clock and display are leds, right. If you can remove the panel where the board is and gain access to the back of it, look for a fuse, similar to a car fuse. The elements are controlled by manual independent switches, that's why they are working. If there is no fuse, or its still good, look for a burnt wire of some sort back there, as you said a power surge went through it.
Feb 19, 2008 | Ovens
Ovens Logo
104 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
