Question about Brother MFC-7440N Laser Printer
Paper jam i am at work using bosses printer and the paper has jammed it says to remove the drum but i dont know how
  • 30 Answers
This is a very easy fix.
  • First, open the front cover.
  • Next pull out the black thing that is right there.
  • The cartridge is inside of the drum, and the drum is what you need to pull out.
So basically, when you open the front cover, you need to pull out the thing you see, and you need to pull it upwards for it to come out. The paper should be under it or behind. Hope this helps! If you need pictures, just email me-eran_4h@hotmail.com. GOOD LUCK!
Posted on May 27, 2010
Broter hl-5170dn in paper jam drum
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot
remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of
the jammed paper from the paper tray
Jul 07, 2011 | Brother HL 5170DN Laser Printer
HL 2140. How do you remove jammed paper from inside printer
You can remove the jammed paper by removing the drum and toner inside the printer.
First Open the front cover, just pull down the cover right above the brother logo. You will see the handle for the drum and toner. Hold the handle and pull it towards you, just use a little force on it. Then remove the jammed paper inside. Just to be sure you can remove the toner from the drum by holding down the green tab on the side of the drum unit. then pull the toner out. Check if there's a small piece of paper inside the drum unit. Put the toner back to the drum make sure it clicks into place. Reinstall the drum and toner back to the printer. It should also click into place. Then close the cover.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother HL 2140 Laser Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Paper has jammed rinter
paper jam is of two types.1.while spolling half paper will come out tom tray.remain jammed in rollers.This can solve by switching the printer power off and remove toner catridge from printer.Then power on the printer.lift the top rollers cover and reset as it is.The paper will come out without any difficult.2.Paper jam inside the toner catridge by rolling itself to drum.Switch off the printer power.Remove toner catridge from priter.Unscrew the toner catridge cover screws.remove drum from toner catridge .Utmost care should be taken while removing jammed paper from drum.Reassemble as it is and set.
mohanraojagan@yahoo.com
Nov 07, 2010 | Brother HL 5170DN Laser Printer
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
Paper jam
Please open the front cover and remove the drum to check the jam. If not in the drum, then check the back cover, open it to remove any jammed.
May 12, 2009 | Brother HL-2070N Printer
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Paper jam on Brother HL-1270N
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
c_hl20_025121.gif Caution
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
    Make sure that the Paper LED is now off and the printer is ready.
Feb 23, 2009 | Brother HL-2040 Laser Printer
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
Brother MFC-7440N Laser Printer Logo
121 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
