I have an E-Machine wired desktop keyboard. It works while in BIOS setup, but does not work once my Mac OSX starts up. I have tried other keyboards, but the same thing happens. Is this a problem with Mac OSX?
Click on this link to troubleshoot your Mac OSX (on PC) keyboard problem:
http://support.apple.com/kb/TS1381
Posted on Feb 02, 2010
My Apple Mac OS X desktop has a problem with responding to my keyboard. I checked the keyboard with another computer, and it works fine, so that is not the problem. what could be issue w/computer?
Well if the other computer you tried it on is a PC, the your issue is probably that you need to download the driver package for OSX. Windows generally had drivers built in.. mac does not.
Oct 04, 2015 | Apple Computers & Internet
Two keyboards, neither type
are the keyboard working well with other computers??
are they mechanical ones or electronic?
Oct 22, 2008 | Dell Dimension 4600 PC Desktop
Help i have a dell inspiron 530s and all of a sudden my keyboard and mouse do not work on when the logo of windows comes on in start up nor the mouse or keyboard work but my keyboard works on f2 and f8...
Try restoring your system bios to factory default and this may fix your problem. If not- post again with results and we'll go from there.
Entering System Setup
Turn on your computer.
When the blue DELL logo is displayed watch for the F2 prompt to appear (black screen / white text).
Once this F2 prompt appears, immdiately press F2 .
The F2 prompt indicates that the keyboard has initialized and is detected. This prompt can appear very quickly. Watch for it to display as the screen powers up, and then press F2. If you press F2 before you are prompted, this keystroke will be lost. There is a small window of time to do this before Windows starts.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then, shut down your computer and try again to enter setup. At setup check your bios version. It may need to be flashed (upgraded). Select load factory defaults to see if that will resolve your PCI issues.
Jan 16, 2011 | Dell Inspiron 530s Desktop Computer
How do you get to the bios (f2) does not work
It depends on the machine. Some require you to press F1, others require you to press Delete, and still others require you to press Enter to get to a menu where you can select the BIOS Setup. These three varieties are the most common ones I've seen, but there are still others that have different ways to enter the BIOS - check the manufacturer's Website, the owner's manual, or search it on the Web.
If your machine is telling you that the keystroke is F2 and it's still not working, you may have a bad keyboard, or your USB keyboard may not be recognized until the BIOS option has expired - try a PS/2 keyboard.
Oct 31, 2009 | Systemax Ascent RTS A14 (980796) PC...
My computer only has usb connection for keyboard. The keyboard does not work during start up, therefore I cannot connect to bios or setup. How do I resolve this issue?
try putting your usb keyboard in another usb slot and see if it works. If not get another USB keyboard and use that. Also make sure other usb deives are working so you know its a keyboard issue and not a usb issue.
Sep 13, 2009 | Dell Dimension E521 PC Desktop
Old keyboard still connected note worthy keyboard
when you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
Sep 08, 2009 | Targus Noteworthy Multimedia Keyboard...
This mb will not accept keyboards
if the keyboard is working fine with other pc's except this motherboard i suggest you to enter the Bios setup by pressing the F2 or Del key before the system boots and set the option Halt On in the Bios setup to----> All error ,but Keyboard
May 08, 2009 | Computers & Internet
Can't enter BIOS
Hi there.
  • Boot the system. Press F2 to enter the BIOS setup.
  • Press ALT-F
  • Press ALT-B
  • Computer will restart and display a message indicating it is re-detecting IDE drives. After a minute or so, Windows will start. Test the device that wasn't working before.
  • If you want to restore other BIOS settings you have set, such as the boot sequence, you will have to restart the computer and enter BIOS setup again.
If this does not work try another usb keyboard in the same port.
Good luck and thanks for using FixYa!!
Apr 22, 2009 | Dell OptiPlex GX280 PC Desktop
On boot with battery or on power same result. The computer boots to window sign on screen but mouse and keyboard do not work. On reboot tried F2 for setup screen which does work but then once at setup...
i would have told you to go into the bios but seen as you say that F2 key does not work on boot indicates that the keyboard has failed, to check this try another keyboard and see if you get the same result, or if the keyboard is USB try it in a different USB port
hope this helps
kind regards
Nov 18, 2008 | Acer Computers & Internet
Dell webpc,,2 short beeps and keyboard error
i can help you with the Post-Code Beeps.
AMI Bios= 2 Beeps. Parity error In First 64k Ram. ( reseat Memory ) Post Failure 1 or more Of the Hardware test Have Failed.
IBM Bios= 2 short Beeps. Post Error ( Memory Possibility ) review screen for details.
AWARD Bios Codes = 2 Short Beeps. Any Non-Fatal Error. Enter CMOS setup to reset.
I,d go for Memory ( RAM ) But first enter bios setup Usually F2 Or Delete escape et,c. Reset to defaults, and see if that solves your Problem.
Mike @ Compurepair.
Mar 07, 2008 | Computers & Internet
29 people viewed this question
k24674
jasbo
jasbo
