Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Can't save data to flash drive - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
or
2) How to put Slax on CD:
http://www.fixya.com/support/r3879348-slax_guide_survival_live_linux_usb_flash
Posted on Feb 02, 2010
The disk in write protect
When formatted, the disk is write protected (there is damage to firmware)
Damage to firmware, there are two types
1. Damage to firmware, data can be saved
2. Damage to firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair Damaged and repair firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Dec 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Describe your 2GB Cruzer Micro USB Flash Drive (SDCZ62048A10) Hard Drive Problem my cruzer data loss
For SanDisk flash drive to save the data, use software, U3 Launchpad. This program is used to saved data, repair damaged firmware, and firmware updates.
If you use the operating system
Win XP, download the software from here SanDisk Support
Win 7, download the software from here SanDisk Support
Hope it helps
Sep 17, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Transcend Jf V30/ 32 gb flash drive. When saving data less than 4GB and after removal of flash drive most data are lost. What can I do ?
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Mar 15, 2011 | Computers & Internet
I have a 80 GB Playstation 3 and the memory has ran out. I purchased an HP external hard drive with 1 terabyte. I have formatted it with FAT32 and plugged it into my system, which recognized it. It copied...
When replacing a hard drive in a PS3, the easiest way to transfer your game data from one drive to another is to use a USB Flash drive. If you are only concerned with the save game data, you can plug it in while using the hard drive that has your save files, go to Game on the XMB, then Game Saves, and select the save data you wish to copy. Press triangle and select copy. This method doesn't work for all games though, because some games will "lock" your save data but there is a way around this.
Instead of manually copying your save files, you can backup your data to the flash drive under the Settings on the XMB, then go down to System Settings > Backup Utility. This will try to backup everything on your PS3, so it is best to have manually transferred as many of the other types of files (music, pictures, videos) off the first hard drive as possible. This means more space will be available for Game saves and Game Data. If you aren't too concerned with reinstalling game data on the new drive, i would suggest deleting these from the first hard drive as well, as they take up much more space and make the back-up process take considerably longer.
Once the Backup Utility finishes, you may swap in the new hard drive and restore the data from your flash drive. Restore is in the Backup Utility menu.
Mar 14, 2011 | Sony PlayStation® 3 (80GB) Console
Sandisk 4gb cruzer micro showing 0 bytes and not accessible, i have valuable data in it
To restore the flash drive you need to format the flash drive, but you willlose the data stored on the flash drive.
Feb 04, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I could n't access my files in my pendrive JF V30
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
Sep 09, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
Can not access my usb scandisk stick. The System see's it but it wants to reformat it.
Mar 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Formated usb forgets data
Flash drives are static , some times they have some proprietary
software pre-installed on them SanDisk are the only ones I know
of with added software pre-installed on them pay close attention
to the data that is being stored , since there is no registry entries
on the flash drive you can only save things such as photos , videos music and Executibles ( your programs exes ) anything else that you save came from your computers registry and can not be saved or reused without the registry . P.S. static drives
do not use the NTFS or the FAT32 configuration , those configurations are only for the operating system .
Mar 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Is a flash drive good for saving documents on my computer? how would i use it if it can be used for this?
Yes , Flash drive is a good way of saving data from your computer it can also act as a back up of the data from the computer that you can access anytime, by simply connecting it to a USB port of computer.
Flash drive can be connected to a computer that has a USB port almost all computer has a a USB port including your computer.
Jan 18, 2010 | Dell Dimension 2400 PC Desktop
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
149 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
