Question about Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag model 920 d/w will not drain
My 3-4 year old Maytag 920 will not drain.removed debris from around screen-no help.cleared drain hose at sink trap-no help.blew out loose debris from around screen-no help.if suction out water-will run until full and float switch kicks in.from that point timer rotates and you hear cycling-at rinse cycles it clicks on and then stops due to tripped float switch.d/w full of dirty water.removed spinner and top part of screen-no help.if remove impellor can i clean out or must i go underneath to find blockage ?
Cannot hear anything at that point
Posted on Feb 19, 2008
  • 49 Answers
Can you hear the drain pump trying to pump? or does it do nothing? when it should be draining
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Maytag neptune front load washing machine will not fully discharge water after the rinse cycle...HELP???
Check the drain hose and clear it from any debris that might be blocking the water from draining out completely. If the drain hose is clear of debris, check and clean the pump. Disconnect the machine from the power outlet before servicing for safety purposes.
Remove the rear access panel to access the pump and disconnect the wiring harness from the terminals of the drain pump and the pressure switch.
Loosen the clamps holding the drain hose and the tub hose to the pump assembly. It is a good idea to spread a towel under the pump before loosening the clamps.
Remove the hoses and rotate the pump assembly counterclockwise to release the pump assembly support legs from the keyed slot in the base of the washer. Remove the pump assembly from the washer.
Clear the pump impeller from any debris that might be causing it to work improperly. Clean the tub and the drain hose.
Reassemble the pump, the hoses, and reconnect the wires to the terminals of the pressure switch and the drain pump. Reinstall the rear access panel and run the machine.
Replace the pump (part #25001052) if water still do not drain out completely.
Remove the plastic bag covering the pressure switch. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
Grasp the pressure switch and lift the nipple of the pressure switch from the pump cap.
Install the pressure switch into the new pump assembly in reverse of the steps above.
Feb 24, 2010 | Maytag Neptune MAH6500A Front Load Washer
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Nov 20, 2009 | Maytag SAV5710 Top Load Washer
Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Sep 26, 2009 | Maytag MDB5100A Dishwasher
I have an old Maytag dishwasher, which came with the home we purchased 20 years ago. i am wondering how water efficient it is; it still works, but I also frequently find it with dirty water which has...
It is as efficient as any dishwasher made today. It is also mechanically better than most made today. Keep it running as long as you can.
Under the sink find the dishwasher drain line,using a piece of wire or string tie the DW hose up under the sink so that there is a rise in the hose from the disposal drain outlet.This way drain water will not go back down the hose.
Aug 24, 2009 | Dishwashers
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag WU203 drain hose
you could go to lowes and buy an air gap to install on your sink run hose from washer comes up to air gap then down to drain if you clever could install under sink just get it high up as you can then down to drain
Dec 31, 2007 | Dishwashers
Maytag dwc7400abw
you have a blockage somewhere probably. if the drain hose plumbed in under the sink, check there is no blockage in this area. also check the drain hose for blockages. if all clear, the fault is probably the drain pump itself
May 05, 2007 | Maytag 24 in. DWC7602 Free-standing...
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
168 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
