Office printing 8.5x11 full bleed possible?
I am looking for an office printer to print high quality 8.5x11 layouts full bleed. Any suggestions?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 73 Answers
Try deskjet c4480 or hp color laserjet p1515
Posted on Feb 02, 2010
7500 dt to print full-bleed
This printer is not capable of printing full bleed. You will have to print on oversized paper and trim it to get dull bleed.
Jan 10, 2014 | Xerox Phaser 7750 Laser Printer
Canon MX870 print alignment. Only occurs
Reinstall the printer driver. Sounds like it is corrupted.
May 09, 2017 | Canon PIXMA MX870 Wireless Office...
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head...
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
My text papers are printing grey instead of black
Suggest you check your print properties page. Look at the Features tab. check the Print in grayscale, print high quality (multiple passes) or black only (one pass).
Hope this works.
Apr 13, 2010 | HP D4360 DeskJet Printer InkJet
Printed photo's are pale and seem washed out. Is there a specific profile for remedying this problem as the profiles have been changed
Go to "start menu", then "settings", then "Printers and faxes". Open Printers and faxes. Right click on your printer. You will see a menu. Find "properties". A menu will open (usually, the first thing you see is "General"). On the bottom, you will see "printing preferences". Click on that. A window will open. It has two tabs: one is "layout", the other is "paper/quality". Look at the layout menu, you will see on the bottom a button named "advanced". Click on it. Find "document options". Click on the + next to it. On the bottom, you should see "printer features" and underneath it "print quality". Try changing the print quality to "high quality". That should improve the quality of your pictures.
Apr 01, 2010 | Canon BJ I6500 InkJet Printer
I want to print a brochure in word or psd and how I can print edge to edge, borderless.
Within MS Word, minimize the "left-margin" and "right-margin" settings/
Use "printer setup" to minimize the margins.
Oct 31, 2009 | Microsoft Office Word 2007 Full Version...
ImagePass-C1 Not Printing the Pantone Colors
you need a set of kodak cards to run full colour set up on your fiery print controller then you just follow the intructions
Oct 29, 2009 | Canon imageRUNNER C3200 Copier
Konica 7022
If you have a server you can do this on the server, the clients will recieve the instructions.
In XP go to printer properties of your 4500 printer. On the General Tab.
Select Printer Preferences, on the tab Paper/Quality change the document size to Letter and paper type to auto select.
(If server) On server do the same in the Tab Advanced under Printing defaults.
Now you can print on Letter (8,5x11), format.
Kind regards,
Mark Peters
Field Engineer.
Nov 24, 2008 | Xerox Phaser 4500 Printer
Full bleed printing
feed the stock thru the Multi prupose tray. Set a custom size in the PDD to 5 mm larger diamension for W and H. this fools the machine to thing larger stock is being printed. feed your original stock. do not scale to fit....and presto, you can print to full bleed...
Sep 10, 2008 | Xante Ilumina Digital Color Press Printer
Mirror image
Printing Iron-on Transfers
Load the iron-on transfers.
With your document open, click File, then Print. The Print dialog box appears.
In the Print dialog box, click Properties, Preferences (or Options).
Select a print quality:
In the Print Properties dialog box, click the Quality/Copies tab.
From the Quality/Speed area, select Normal or Better.
Select a paper type:
In the Print Properties dialog box, click the Paper Setup tab.
From the Type area, select Iron-on Transfer.
If your software program does not have mirror or iron-on settings, select a print layout:
In the Print Properties dialog box, click the Print Layout tab.
From the Layout area, select Mirror.
Click OK.
To print your iron-on transfers, click OK.
NOTE: To prevent smudging, remove each iron-on transfer as it exits the printer and then let it dry before stacking.
Mar 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
418 people viewed this question
jasbo
jasbo
