Question about Poulan Genuine Weedeater Part # 36006-128
Doesn't seem to be getting gas. Gas in spark plug
Doesn't seem to be getting gas. Gas in spark plug opening and it will start and run for afew seconds.
  • 25 Answers
Your carburetor needs to be rebuilt. It has thin diaphragms that get hard after a couple of years, sooner in hot climates. Also check your fuel lines for cracking.
Posted on Feb 11, 2010
I have a John Deere La115 that stopped running, I checked the plug, blew out the fuel lines and there is gas in the filter but does not seem to be getting to the carb. How can I figure out if it is th
if it doesn't fire on starting fluid then you have a spark problem unplug the engine connector and recheck for spark if you then have spark check your safety switches if still no spark check the coil
Jun 06, 2012 | Garden
18.5 hp Briggs & Stratton no spark after running out of gas
I believe you are right about heat induce electrical problem.
About all there is for ignition is the coil and breaker points.
Mar 05, 2017 | Briggs & Stratton Measuring Tools &...
17 hp briggs smoking badly . found oil in gas. took head off cleaned valves and piston. took off carb and checked float. checked breather seems ok. starts right up. littlesmoke then more as it warms up...
The only way oil can get into gas is if someone adds oil to the gas! Drain gas tank. Put Clean gas in and try it then. Oil in gas usually fouls the plug so if it doesn't run by now, check the firing in the plug.
Dec 16, 2011 | Measuring Tools & Sensors
Doesn't start has spark @ plug fuel @
try starting meaning pull the rope 6 times and then check the spark plug if its wet clean it or try a new plug, if its dry your not getting fuel in the cylinder which means carb problems. if you have a seringe or something to put some gas into the spark plug hole then install spark plug and try it. if it runs for a couple of seconds then you need to focus on the carb. only put a small amount of fuel in the plug hole if you try it otherwise youll be pulling on the rope for awhile before it will start. hope this helps.
Jul 06, 2011 | Echo CS400 18" Chain Saw
My 1992 plymouth voyager 3.3sl started lossing pressure while driving and regain pressure afew mints later it will good then repeat. then one day i was driving and it stop driving it would ture over but...
sounds like fuel starvation.
did you run the car to the limit or run out recently?
you may have sucked up dirt from the bottom of the tank which is now blocking your fuel system.
if you crank over for a while and dont smell gas at the exhaust then it could be there is not fuel getting through.
remove the fuel line from the engine and see if fuel pumps out when you turn over engine.
just do a short turnover with pipe into a jar or some vessel to catch the gas.
if that is ok, replace pipe, also check fuel filter is not blocked, if one is fitted.
then there maybe a blockage in the carb or injectors remove spark plugs and crank over and see if you can see gas vapour.
warning do not use flame to see as this will cause explosion.
I hope this was useful.
May 23, 2011 | 1992 Plymouth Voyager
I put gas in the oil and oil in the gas can it be fixed
As far as gas in the oil I presume you are talking about bar oil. I wouldn't worry to much about that. Empty out all you can and refill with bar oil. With oil in the gas I would drain all I could out of fuel tank,then remove sparkplug and pull srarter rope several times. With plug still out i would pour 1-2 ounces of of gas into plug opening and let it set for a few mins.,then dump out remainging fuel. Once again I would pull starter rope several times. Reinstall plug and refill gas tank with proper fuel oil mix. Try to start. If you're lucky you can get it to fire and burn off excess oil in afew pulls. If you can get it started I would run for just a couple of mins,then shut off and drain gas again. Hope this helps. Thanks.
Nov 13, 2010 | Poulan Pro Chain Saw 46cc 20"
Car will not start fual pump shut off swich is
ok so now check for spark by removing a spark plug wire and sticking a srcew driver into it and then putting it next to metal on engine but not touching have some one crank it over and watch the screw driver for spark. sounds like one of the two crucial elements is missing you have gas and now you need spark to run.
Jan 06, 2010 | 1994 Ford Taurus
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Car won't start
Disconnect the air filter tube from the throttle body. have someone step on the gas pedal or simply open the throttle valve then try to check if you smell gas inside the intake manifold. if you do smell gas, then you have an ignition problem. check if the spark plugs are getting sparks.. a general mechanic can easily isolate the problem. Have it checked.
Jun 25, 2009 | 2001 Oldsmobile Alero
Poulan Genuine  Weedeater Part # 36006-128 Logo
188 people viewed this question
Top Poulan Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Poulan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
