Question about Dell 926 All-In-One InkJet Printer
Had this printer for 2 years. Everything I print
Had this printer for 2 years. Everything I print now is showing wide yellow streaks.
3 Suggested Answers
SOURCE: streaks on left side
Hi
Solution here
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&thread.id=22414&view=by_date_ascending&page=1
Yop
Posted on Feb 12, 2008
  • 3422 Answers
SOURCE: Dell 3100cn streak on left side of paper
Just pull all the cartridges out of it and tried to clean it throughly. IF not you have to replace the drum and the cleaner may also be bad.
Click HERE for the user manual for some troubleshooting steps.
Main support number: 888-560-8324, 800-624-9896
Goodluck.
Posted on Feb 22, 2008
My printed page has yellow streaks on it. I have cleaned the roller mat, it just gets junked up again
I had the same problem. I was using a refurbished yellow cartridge which have never given me problems before. This particular cartridge ran fine until it was almost empty then I had yellow streaks showing up all over my pages and the roller in the printer was covered with yellow ink. I cleaned it a few times but that made no difference until I replaced the ink cartridge. Now it is printing clean again.
Jun 24, 2009 | HP Office Equipment & Supplies
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Dark streaks
Dark streaks are an indication of "burned" or overheated ink. This will occur when the printer sets for a long period of time and nothing is printed. The problem will usually disappear after 50 pages or so, unless the printhead is damaged.
If the print remains dark, the printhead will need replaced.
(Very expensive)
(Dark print can also be caused by using Non-Xerox ink)
Sep 10, 2008 | Xerox Phaser 8400 Laser Printer
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Black streaks on printout
Your fuser is worn out. Needs to be replaced.
Mar 27, 2008 | HP LaserJet 5p Printer
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Dell 926 All-In-One InkJet Printer Logo
13 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
