Question about Dmm Designer Water Filter Reverse Osmosis Faucet Antique Bronze
Repair RO faucet -- it drips Watts brand
Repair RO faucet -- it drips -- is there a washer that can be changed -- Watts brand
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
It is possiable, taking off the handel and the handel body should reveile a washer ,that you can try replacing.
Posted on Mar 28, 2010
Constant drip of water on my Franke manor house gooseneck bridge faucet. how do I repair the faucet from dripping water?
Check the washers and o rings that are a part of the faucet assembly. If possible tighten fittings.
Aug 23, 2017 | Franke Plumbing
How to stop a driping tap
Try to follow these two you tube videos and see which one applies to your style of faucet.
Good luck.
How to change or tap washer to stop dripping tap or replace the type of...
How To Fix Dripping Tap Washer Change Plumbing Tips
Aug 05, 2014 | Plumbing
How do i stop a slow drip in a tub faucet?
A drip is caused by seepage from the water supply. Remember the water supply enters your home under pressure, so there must be a watertight seal holding back the incoming water when the faucet handle is in the OFF position. That seal is usually created by a washer pressed tightly against the faucet seat. Obviously, when the washer or the seat is not functioning properly, a little water can seep through and drip out of the faucet spout. To stop the drip, all you usually have to do is replace the washer or repair the seat.
Jun 01, 2012 | Home
We have a steadily dripping tap. Can you please help? thank you.
You don't say anything about what kind of faucet you have, so this may not apply. But if yours is the kind with handles you turn to control the water, you probably have worn-out compression washers. In this kind of faucet, water is shut off by pressing a rubber washer on the end of a threaded stem against an opening in the faucet body. When you turn the handle, you move the washer away from its seat and the water can flow. Over time the washer gets worn and no longer seals off the water. Also, the valve seat the washer presses against can wear and allow water to sneak past the seal. The result is that annoying drip or a steady trickle.
This site, among many others, shows how to change a washer and fix most drippy faucets. If you search for "repair a leaky faucet" you'll find lots of sites to pick from, including many with videos. If you faucet is not a compression type, a single-lever cartridge for instance, there are links to other repair procedures.
If your faucet is old and the parts very badly corroded and worn, you might want to fix the leak by replacing the entire stem as a unit. You can find replacement stems for most brands of faucet at big-box home improvement stores and at many hardware store. It's a little more expensive, but often much easier to unscrew the old one and pop in the new than to start trying to get the old washer off the stem.
A last tip: Whenever you do any work on a faucet, remove the aerator from the spout and run the water to help clear the line. If you just turn the water back on and run the faucet, debris that was kicked up during the repair can clog the aerator screen. Then you're left wondering why you get only a weak trickle or no water at all after you fixed the trouble.
Mar 10, 2011 | Microwave Ovens
MY SINGLE HANDLE SHOWER FAUCET DRIPS RAPIDLY. THE ONLY BRAND NAME MARKING IS "MASTER PLUMBER". iS THERE A REPAIR KIT FOR THIS FAUCET?
Those faucets are made by different companies and they put their name on them. Delta Price Pfister most likely. Sorry but you will need to pull it apart and see which it is. That is a hardware brand faucet and may be made by any of the major brands.
Feb 08, 2011 | Delta & Single Handle Shower Faucet
Freeze proof faucet dripping badly (hardly used 6 yr old) bolt holding plastic handle seems pretty well rusted on. I'm trying toi figure out if there is a servicable washer that needs replacement.
I assume that you are refering to a wall mounted hydrant. If that is the case, most do have a bibb washer at the end. You have to remove the packing nut and then the stem to get to it. Some brands you can do this while the handle is still on. Hope this helps.
May 12, 2010 | Plumbing
JADO BATHROOM SINK FAUCET DRIPS
Jado are ceramic disc cartridges no washers you should replace both sides.You need to remove the handle and unscrew the cartridge
Mar 13, 2009 | Plumbing
Leaking faucet
The faucet is slowing wearing out. You can live with this little drip or have a repair kit installed in the faucet. If you are handy you can do this yourself.
You must be sure to get the repair kit that matches your faucet. good luck
Jan 17, 2009 | Plumbing
DRIPPING OLD BEVERAGE AIR FAUCET
New faucets are easily had from many places like beveragefactory.com, northerbrewer.com, austinhomebrew.com, micromatic.com, etc. You should also be able to find replacement washers/o-rings for your current faucet, but it may require an email or phone call to one of the sales reps to locate one. If you decide on a new faucet consider a Ventmatic (Shirron) forward sealing faucet. Much better design that drips less and doesn't stick after sitting a few days. The only issue I've seen is that the machined grooves in back of the faucet may not mate up with your current shank requiring a machined (as opposed to cast) shank to match.
Nov 01, 2007 | Beverage-Air MT27 Beverage Cooler...
Washer takes forever to fill
You said you checked the screen at the faucet end, did you check the one at the washer connection? Most washing machines have a wire mesh screen which sits inside the plastic connector that the hose connects to. You will have to use a small pointed object (like an ice pick) to remove the screen and clean it. Be careful not to damage it, I have ruined them on more than one occasion and had to replace it with a new one. If that is not the problem, there is likely a problem with the valve that is controlled by the hot/cold knob. I am not familiar with your washer brand, but mine required quite a bit of disassembly to get to the valve and switch, and in my opinion is a job better left to the local repair man.
Jun 04, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Dmm Designer Water Filter Reverse Osmosis Faucet Antique Bronze Logo
600 people viewed this question
Top Dmm Plumbing Experts
Donni Steen
Tom Chichester
Are you a Dmm Plumbing Expert? Answer questions, earn points and help others
