Question about Cell Phones
The screen on my HTC Ozone is completely black. No backlighting...can't see anything, as if the phone were powered down. The phone still operates. Have received & sent calls. Just no screen...
    President:
  • Cell Phones Master
  • 2,923 Answers
The first thing that you should do is to remove the battery from the phone and leave it out for 5 minutes. Then try turning the phone back ON and see if that would soft reset the phone.
Next is to try another battery. Though you can call or receive a call, we're not sure if your battery is working correctly and could provide enough power for the phone to operate properly.
Next, try to upgrade the firmware of the phone.You may need to contact the manufacturer for firmware upgrade because they know what version of firmware that would work best with your phone.
If you're done with the basics, then have the manufacturer or a local tech to replace the LCD or any defective components and that should not cost too much.
Good luck and have a good evening!
Posted on Feb 02, 2010
Power turns but screen stays black no
Sounds like you need a new LCD Screen(is the screen a little lit up or completely blank) If completely blank than most likely the LCD needs to be replaced if it appears to be slightly lit up than most likely it is a software related issue.
Mar 31, 2014 | HTC Cell Phones
Htcv6175 is frozen with htc on screen
1. Remove Battery
2. Hold Power Button for 30 Seconds
3. Reboot Phone - Power on
Most likely your downloaded an app that has currupted a file in your phone.
Sep 14, 2011 | HTC Ozone XV6175 Cell Phone
I had to take out and re-insert the battery of my HT Ozone phone. Now I get a white screen saying that I must press send to reboot it, however, I can't press send - it won't leave the white screen....
Many smart phones will have problems if you remove the battery without powering them off first. The easy fix for the state your phone is in is to run your battery down. If you get it to the point where it will auto power of anyway, and leave it like that for at least an hour with the battery in, it should reset the power management.
May 06, 2011 | HTC Ozone XV6175 Cell Phone
Htc ozone stuck on htc start up screen
Remove the battery while the phone is on. Hold down the power button for at least 30 seconds. Put the battery back in and press the power button. If your phone still hangs on the startup screen you may have a corrupt boot file. If your phone is still under warranty call your service provider and they will help you. If it is no longer under warranty contact HTC: 866-449-8358. I hope this helps.
Mar 03, 2011 | HTC Ozone XV6175 Cell Phone
HTC herm200 phone not working properly.. :(
its just the display problem u can just replace the display and it will be done!
Jul 15, 2010 | HTC Cell Phones
Need to calibrate my phone
click on start,settings,screen or start,settings,power,adjust backlight,screen!
Mar 19, 2010 | HTC Touch Cell Phone (Unlocked) - Soft...
My HTC Ozone is locked up again. cant even get it to start up. what do I do?
Step 1: Power down the phone. If your phone is already powered down, you may skip this step. Note: Removing the battery, while technically powering down the phone, is not the correct method to make the following steps work.
Step 2: With your left hand, press and hold the VOLUME DOWN button that is located on the side of the phone. Continue pressing the VOLUME DOWN button and press the SEND button. With both the VOLUME DOWN and SEND button pressed, use your right hand to press the POWER button.
Step 3: A gray screen will appear asking you three options. Pressing the VOLUME UP button on the side of the phone will be the correct option to hard-reset your phone to ROM default.
Step 4: Press SEND to verify choice.
Mar 01, 2010 | HTC Computers & Internet
G1 backlight shows but nothing else
Everything is working fine except the operating system (firmware). A clear case of corrupted firmware. Please get the firmware reinstalled. And you will find that all your problems have vanished. The reason could be a virus or incorrect switching off or powering it on on low battery when the phone switches off on its own. Anything. But reinstalling is the answer.
Dec 12, 2009 | HTC G1 Smartphone
Remove verizon software from HTC Ozone
Go to PPCGeeks.com and go to the forums and look for your phone. There are all sorts of help on that site to do things like you are looking for
Good Luck
Oct 08, 2009 | HTC Ozone XV6175 Cell Phone
Backlight went out
the HTC needs to be reflash to correct this issue...so take the phone to a mobile service center to have that done or try sourcing it online.
Jun 09, 2009 | HTC Touch HD Smartphone
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
