Identifying an electronic component
I have a component that looks like a resistor but only haves two colour bands could you suggest what it may be it is on the circuit board of an incubator
    Scholar:
  • 79 Answers
Some wide-tolerance resistors only had 2 color bands. The body is the 3rd color. It could also be an inductor or capacitor. It really depends on its place and function in the circuit.
Posted on Mar 22, 2008
In the leads is Cylinder with a gold, brown, black & silver band. Is it a fuse? How do I get one?
The cylinder is a resistor. The value and the tolerance is denoted by the coloured bands and the wattage rating by the physical size.
Available from electronic repair shops and constuctor outlets.
The colour code is quite universal and helpfully included in most catalogues.
Apr 19, 2016 | Measuring Tools & Sensors
I need schematic diagram for samsung ct-14h4 because some of the components are hard to determine like resistors
usually a resistor have 4 to 5 color bands,an inductors looks like a resistor but have only 3 color bands and a capacitor also looks like a resistor but there is no gold or silver color bands,even though it has a color band also...
Jul 19, 2011 | Samsung Televison & Video
Colour coding of resistors and placing ie R???
Look up "resistor color code" online. The first two color bands are numbers and the 3rd band is how much you multiply the number by. For instance, a Red, Brown, Orange is a 10,000 ohm (10K) ohm resistor, the orange means 3, but 3 digits. If NOT totally burned-up, you can measure the resistor if you disconnect one lead from the circuit.
Jan 12, 2010 | Pioneer VSX-405 Receiver
TV resistor mystery
Go to an electronics parts shop and take the damage resistor with you.
The bands are a colour code (the first two bands indicate the first two numbers, the 3rd one is for the number of zeros and the fourth one is the accuracy of the value e.g. 5%, 10%) for the value of the resistor.
The physical size of the component gives an indication of the current that it can carry.
Dec 19, 2009 | Washing Machines
Resistor burnt up, inable to identify due to skorched bands
I have the same exact problem in a 12 volt Lincoln battery charger. Burned resistor in R5.
May 07, 2009 | Lincoln 14.4 Volt Cordless Grease Gun,...
Schematic (or just R10) for Rampage AMP522A Car Audio Amplifier
2 years later... I just picked one of these up at a yard sale... R10 is actually a diode. The code is buried, but ends in N1.
Hope this helps!
Sep 14, 2008 | Audiovox AMP522A Car Audio Amplifier
Soldering iron tips
It is very tempting to start soldering components onto the circuit board straight away, but please take time to identify all the parts first. You are much less likely to make a mistake if you do this! 1. Components stuck onto paper Stick all the components onto a sheet of paper using sticky tape. 2. Identify each component and write its name or value beside it. 3. Add the code (R1, R2, C1 etc.) if necessary. Many projects from books and magazines label the components with codes (R1, R2, C1, D1 etc.) and you should use the project's parts list to find these codes if they are given. 4. Resistor values can be found using the resistor colour code which is explained on our Resistors page. You can print out and make your own Resistor Colour Code Calculator to help you. 5. Capacitor values can be difficult to find because there are many types with different labelling systems! The various systems are explained on our Capacitors page.
Aug 27, 2008 | Cooper Industries Mcm Tool P2C Cordless
Resistor has failed and heated in home theatre amplifier
If your are still looking for this...
According to the service manual, R218 is a flame proof carbon resistor of value: 4.7Kohm 1/4Watt
Marc
Aug 23, 2008 | Audio Players & Recorders
Samsung HCN4226 Convergence.
Did you remove one side of the resistors from circuit to check them? If you leave them in circuit a blown resistor will test good as it will read the resistance from the surrounding resistors. Usually its the 3.9 ohm resistors identified bu the bands orange,white ,gold and red. and also the 150 ohm identified by the bands brown, green, brown and gold
Jun 23, 2008 | Televison & Video
DVDPlayer/Freeview box (believed to be a generic one with a Wharfedale label)
R10 just means Resistor # 10 unfortunately this is just to make the manufacturing process easier.... However reistors are marked with their value(using coloured bars), if you can read the bars you can get a replacement for it, and hence if you can decode the bars you will know what the value of that resistor is Black = 0 Brown = 1 Red = 2 Orange= 3 Yellow= 4 Green = 5 Blue = 6 Violet= 7 Grey = 8 White = 9 therefore if you have a sequence of red green black then you have a 250 ohm resistor, gold, silver and bronze bands on the other end of the resistor designalt tolerance and should be noted Just hope that it was only the resistor that got toasted Good luck
Oct 04, 2007 | Televison & Video
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
