Question about Refrigerators
Dripping from freezer
We have water dripping down the front of the freezer, freezer fan doesn't seems to be running, and we can't find any leaks. the freezer is still freezing, however. checked the seals and they were fine.
    Scholar:
  • 91 Answers
WATER DRIPPING FROM THE FREEZER DOWN TO THE FRIDGE SECTION MEANS YOU HAVE A CLOGGED DRAIN, WHEN THE FRIDGE GOES INTO DEFROST CYCLE, IT MELTS THE ICE FROM THE COIL, THIS WATER HAS TO GO DOWN THE DRAIN TO THE TRAY LOCATED UNDER THE FRIDGE BY THE COMPRESSOR, BUT SINCE UR DRAINIS IS FROZEN, THE WATERS HAS TO FIND ITS WAY OUT SOMETIMES DRIPS TRU THE AIR VENT, AN RUNS DOWN TO THE BOTTOM OF THE FRIGDGE SIDE, AN WHEN YOU OPEN THE DOOR YOU WONT SEE IT, BUT U WILL NOTICE THE WATER ON THE FRONT LATER U JUST WONT KNOW WHERE IT CAME FROM...!
IF THE FAN IS NOT RUNNING YOU MIGHT HAVE TO REMOVE THE PANEL ON THE FREEZER SIDE AN SEE WHAT IS GOING ON, A BAD DEFROST DRAIN CAN CAUSE ICE ACCUMULATIONS TO THE POINT WHERE THE ICE WOULD BE SO MUCH AN NOT ALLOW THE FAN BLADES TO SPIN, CAUSING THE FAN MOTOR TO BURN, AN OVERHEAT , BUT THE PROBLEM WOULD BE THE DRAIN, AN THE WATER YOU SEE IS THE WATERR THAT MELTS FROM THE DEFROST CYCLE
Posted on Feb 01, 2010
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a Kenmore Side by Side with the ice maker and water on the freezer door. I just hear water dripping and then running, and used a flashlight to look under it. There seems to be a driptray under the...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Feb 04, 2011 | Kenmore Refrigerators
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
Makes ice fine but the water drips down the back of the freezer running into the ice tray - help
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jul 10, 2009 | KitchenAid Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
