Question about Kenmore Freezers
Door won't close stay closed or seal
The door won't stay closed or seal and freezer is frosting up
    Problem Solver:
  • 7 Answers
Check gromets on hinges for wear. check weight on doors is it causing the door to droop? are the gaskets cracked? more information is needed if possible.
Posted on Feb 02, 2010
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Whistling noise freezer close
Hello sangpark003 - Often when the unit is making a whistling noise, it is because it is pulling air from the outside. Sometimes a poor door gasket could be causing the whistling. You may check if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. However, if issue persists, I would personally contact a professional to accurately diagnose the refrigerator to determine the root cause to reduce the risk of unnecessary parts or to confirm if it is a normal operation noise.
Mar 28, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why is there Water on floor under my freezer
Hello C. Richard Robinson - Is the door being kept open too long or frequently? If so, try removing the items needed from freezer ahead of time so the door is not open as much. However, main possibly could be a poor door seal. Try checking this by placing a dollar between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If nothing is stopping the door then the gasket will need replacing and adjusting by a professional.
Jan 18, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why is water leaking from door seals
the seal itself may be bad. coat the seal lightly with lipstick (your choice of color) close door GENTLY then open and check coverage and evenness of lipstick. any gaps will show lack of seal.
Aug 27, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
How do I know if the door seal on my up-right freezer needs to be replaced?
you could just look at it and see if there is any damage, but most likely the unit is just not level, and the door isent closing correctly , of corse if getting frost inside the seal is not working correctly look for damage or door misalinement
Jul 27, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My woods upright freezer keeps frosting up at the top with several inches of frost. It is a manual defrost freezer. Any suggestions?
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Dec 17, 2008 | Woods Upright Freezer MU07W
Not sucking out air when door closes anymore
run your hand around the freezer gasket with the freezer closed slowly and see if you feel any cold air,also check corners they leak to,frost is caused by warm air getting into the freezer or the defrost system is failing,let me know what you find-mike
Oct 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright Freezer self defrosting
THE (SUCKING AIR) OCCURS WHEN THE TEMP IS VERY LOW IN THE FREEZER AND YOU LET WARM AIR IN BY OPENING THE DOOR. WHEN THE DOOR IS CLOSED, THE WARM AIR IS COOLED CAUSING A VACUUM IN THE FREEZER. IF THE DOOR SEAL HAS A LEAK AROUND IT, THE SUCKING SOUND WILL NOT TAKE PLACE. CHECK THE DOOR SEAL FOR A GAP AT ONE OF THE CORNERS OR ALONG THE SIDES,BACK, BOTTOM, OR TOP.IF THE SEAL IS O.K., HOW IS THE TEMP? IF THE TEMP SEEMS WARM, YOU MAY NEED TO CHECK THE SEALED SYSTEM. LOOK AT THE FROST PATTERN ON THE EVAPORATOR. IS IT COMPLETE AND UNIFORM? IS ONLY PART OF THE EVAPORATOR FROSTED BACK? IF THE ENTIRE EVAPORATOR IS FROSTED BACK UNIFORMLY, THE SEALED SYSTEM IS O.K.
Apr 01, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frost in the freezer
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Mar 24, 2008 | Freezers
Frost in Kenmore frost free
Although you say the seal is fine, this is almost certainly due to air getting in. With the door closed check that there isn't a tiny gap with a strip of thin card or plastic. Of course if air is getting in then it must also be getting out somewhere else so probe all around the seal.
Oct 01, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
121 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
