Question about Malber WD1000 Front Load Washer/Dryer
Where can i buy the electrical cords for both washer and dryer???
I need the electric cords for both malber washer and dryer. They were chewed up by my pitbull while waiting for installation.
  • 129 Answers
Call 270-843-3272 or 1-800-457-3104
Posted on Feb 02, 2010
Malber 1000 started leaking from the bottom. Water is coming from underneath the machine in the area behind the filter area
Usually what I have found is a small hole in the drain hose or coin trap, sometimes mice chew them and sometimes It is an abrasion wear from the balance brick rubbing. pretty easy fix though.
May 06, 2011 | Malber WD1000 Front Load Washer/Dryer
I need a 220 volt timer for Malber TD700 drier.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 02, 2010 | Malber TD700 Electric Dryer
My Malber TD800 Dryer runs but will not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rrtrt
Aug 22, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
Malber td 700
need to no where to get belt for malber td 700?
Mar 05, 2009 | Malber TD700 Electric Dryer
Malber Company - Italy. Address
need to find a manual for Malber WD8008
Oct 25, 2008 | Malber TD700 Electric Dryer
Dryer does not heat
I don't know this machine, but I know Malber single tub machines well and this problem in the Malber machines is alost always due to a worn out heating element, similar to the heating element in an electric oven or electric stovetop range. If you have had the machine for at least several years, and noticed that the dryer was becoming less effective, then I bet it's the heating element which needs to be replaced.
Aug 01, 2008 | Siemens WK61420GB Front Load Washer /...
Opening the Malber TD700 dryer
Remove the two top screws on the back center (plastic part) with a Torx 20 screwdriver and the top will come off.
Jul 25, 2008 | Malber TD700 Electric Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
90 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
