All work missing on full hard drive
I have 2 identical lacie hard drives one is almost full the other is practically empty.
today i pluged the full hard drive in for the first time in months and it has re- named its self 'storage' and shows 947 gig of free space. dose this meen ny work is lost?
    President:
  • 281 Answers
Upon start up I see the icon on my screen but then disappearing and reappearing along with all my other icon. the Lacie is disrupting my entire desktop & when I shut it down (Lacie) everything goe
I think the problem is because mounting problem of the logical drive .In this case to access your data in the drive you just need a macbook hard drive recovery tool .Remove the drive from your pc install the drive in some other mac pc and start it in target mode .Install this recovery tool and start recovering files but save it in different healthy drive .I am suggesting this tool because it works good for my missing partition problem.But purchase the full version to get good results.The demo version link is here...
Feb 03, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I just bought Lacie rikiki hard drives. As I put it into my computer the assistant starts. Unfortunatelly after few minutes the process stopped and the capacity is 465 GB instead of 500 GB. Is there any...
Hi.
This is normal. You will never get all the capacity for a USB key or a hard drive. The missing space is for format purpose and hard drive maintenance.
Hope it helps
Feb 08, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
My "t " bird hard drive fell onto floor from about
The '1TB' device is 10 to a large power.
The '930GB' is 2 to a much-larger power.
Since '1GB' is 1,073,741,824 bytes,
multiplying 930 times 1,073,741,824 is equal to 1TB.
So, your device is 100% empty -- all 930GB are "free" space.
Oct 31, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
`lacie hard drive
empty your trash. and youu be pleased
Sep 03, 2008 | Computers & Internet
Information used- capacity used and available
Re: deleting the files, did you drag the files into the trash bin and then empty it? The files don't actually leave your drive until you 'Empty Trash' on your mac's doc. Hope this helps, not sure about your startup disc problem.
Apr 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Drive making loud clicking sound when spinning up and won't mount
HI Koberlin1:
Typically, RAID0 requires identical drives.(size) If you mix brands though; there may be subtle factors that cause problems. WD's 250GB might be a "251.2GB" vs. Hitachi might have a 245.44GB ..
As long as your close (in a PC) you should be fine. However, best practice would be to match the drives.
Keep in mind with enclosures: heat is the enemy. Plastic holds heat; and the next set of drives will die the same way. At TechRx, Inc. http://techrxgb.com I recommend aluminum or some type of metal for an enclosure.
Feb 28, 2008 | LaCie Big Disk 500 GB Hard Drive
Drive Full After Backing-Up Just Under 4gb of Files
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Feb 07, 2008 | LaCie (300728U) 250 GB Hard Drive
jasbo
jasbo
