Question about Epson Stylus CX3200 All-In-One InkJet Printer
After every line of black text there is a light blue line.
After every line of black text there is a thin light blue line accross. With photo there is a thin light blue line every millimeter. With photo it starts about 1/2 inch from the top with a 1/8 inch light blue line accross followed by a line every millimeter, and at the bottom the same heavy light blue line about 1/2 inch from the bottom.
  • 677 Answers
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 02, 2010
Printing thin black and blue lines across cd
my epson stylus photo r350 prints, but it has a line
Oct 02, 2010 | Epson STYLUS R350 Photo Printer
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
When i print a page black ink text thin blue lines appear also a blue ink blob
Method 1:Remove your colour cartridge wen you require only balck ink[The blue lines are often signs of empty cartridge]
Method 2: while printing select 'Use Black Ink Only'
Oct 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
I have a black line accross my LCD t.v. screen
if it is a thin black line then it is probably a line of pixels out. if this is the case, the whole screen will have to be replaced and that can get pricey. i would suggest that you get it checked out by a tv tech and get an estimate, but it'll probably be cheaper to just get a new one
Oct 21, 2008 | Televison & Video
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Epson Stylus CX3200 All-In-One InkJet Printer Logo
220 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
