Question about Canon PIXMA iP4000 InkJet Photo Printer
I tried to load regular 8 x 10'' paper into my brand new Canon ip4700 from the bottom tray,but it wont engage. Suggestions?
SOURCE: Canon i865 6x4 photo tray
Embarrisingly simple fix. The printer was pushed up close to our wall thus not allowing to the paper feeder sit back normally. Therefore the photo tray was not sitting correcly. Once placed in the proper position, it all worked fine.
Thanks for the response though.
Kind Regards.
Posted on Jul 11, 2008
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
  • 5 Answers
SOURCE: Canon iP4700 with error 6C10
after youll be sure that you have communication with your internet modem ! delete your printer from your computer and install it again. at list thats what i did with my mp640 on my mac book. system preferences/print + fax. i suppose its something similar with the pc. i solve my problem this way. hope i help.
Posted on Jun 26, 2010
SOURCE: have just got canon ip3600 printer and can't seem
You may not have removed the piece of packing foam that lies in the track under the printer head. It is a long, narrow dark grey piece of foam that is wedged tightly in the track and is accessible when you lift the top cover. Unlike the pieces of orange tape it is hard to see and it is not shown in any of the setup instructions. If you don't remove it it prevents the paper in the A tray from moving and generates the "paper empty" message.
Posted on Sep 15, 2010
  • 1218 Answers
It's probably a waste absorber issue.
A fix from FixYa Support:
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
3. While holding the Power button, release the Resume Button.
4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
http://www.fixya.com/support/t5998845-error_code_6c10_mean
Hope this helps.
Posted on Sep 27, 2010
Canon pixma pro 100 - "support code : 1000 no paper. Load the paper in the rear tray correctly and press the RESUME button on the printer". How do I fix this?
Try again! Remove the paper from the rear tray. Turn off the printer. Load the tray again making sure that it pressed frimly in and not over loaded - say about 30 sheets. Turn printer on again and see if it is ok. If still the same problem, get in touch with supplier or maker.
Mar 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
How can I fix error No. 6A80 on my Canon Pixma iP4700
Hi, That error may cause of a paper jam, check your printer if there is blockage and then remove those blockage if no blockage, and the error still appear try to reset your printer.
To reset follow this:
1. Turn off the printer.
2. Pressed simultaneously for 10 seconds on the following buttons:
3. Release the button "On / Off".
4. After a few seconds release the other buttons.
Thank you for using FixYa
Nov 15, 2010 | Canon iP4700 InkJet Photo Printer
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
HP 7150 inkjet printer stopped loading paper.
Hello
Happy new year and start reading solution with Smile and trust.
Based on information you have provided I understand that your printer has stopped loading the Paper.I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
Please check the Following Link to get the guidelines
"How to Load Paper" its silly to ask you but its better to keep information updated
Try by Following the steps below to correct the issue:
  1. Disconnect power to the printer.
  2. Remove all photo paper from the Photo Tray.
  3. Push the Photo Tray completely into the printer.
  4. Snap the Photo Tray out (towards you) sharply.
  5. Reconnect power to the printer.
  6. Print a self-test on 8.5 X 10 paper.
  7. Engage the Photo Tray.
  8. From the Printer Toolbox, select Calibrate the Photo Tray.
If the above solution wont work then there something to do with the Adjustment/alignment of the Tray.
Paper is not picked due to the Try --
If you see inside there will be a small rubber which need to be clean by the spirit .. Check this out as well .. as i tried on my printer and it works
Do slow and with care --
If it works Vote me
Cheers
Tejodhar Atreya
Jan 04, 2010 | HP PhotoSmart 7150 InkJet Printer
Printer says no paper, but there is. Problem loading?
If not paper jam may has some problem with feed rollers on printer.First make sure that option to feed from cassette is turned on.Check this on maintenance mode.Аs the printer is in warranty better don't touch anything else and call Canon.
Nov 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
Jun 12, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Switch the way the paper comes out of the machine
Sounds like your tray settings are incorrect. Make sure that if the tray is set to 8 1/2 X 11 in the menu settings(not 8 1/2 X 11R) that the paper is set in the tray to feed the long edge first. The machine is capable of automatically rotating the image to fit the paper as long as the paper is set correctly.
If you prefer to feed short edge first then set it for 8 1/2 X 11R.
Oct 14, 2008 | Sharp AR-M205 Copier
Error - Canon MP830
this Model has a paper tray on the bottom. Put some paper in the bottom tray and then voila..I had the same issue and i looked and the tray was empty..put some paper in..works just fine
Aug 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
22 people viewed this question
old marine
old marine
