Question about Amana AEW4530DDS Electric Single Oven
Touch pad Number 4, 8, and 9 stopped working. From the previous post, it sound like a keypad assembly. Is this an easy fix, or does it require a profession?
  • 49 Answers
It requires a professional due to electrical connections
Posted on Feb 19, 2008
Ge double wall oven, model number jkp26gotibb has an f1 error code. Part is no longer available. Is there any other way to fix this problem with out replacing the whole oven.
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 16, 2010 | GE Built-In 24" Double Electric Wall Oven
Getting an F1 error. Oven shuts off F1 will not stop beeping
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
Read
Nov 21, 2010 | GE Profile JKP56 Electric Double Oven
I have an accubake system electric oven and stove. When I tried to set the temperature on the oven the degree number kept rising to 500 degree on its own. Now it is displaying E0 F2 on the screen. Whats...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Aug 09, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a Kenmore Wall electric oven unit that the heat element at the top is working only and F2 is what comes up and continues to beep. The heat is extreme. WE are wondering if we should just get a new...
Jul 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven givs ma arrer massage C-F later F2 E0
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!##
Oct 02, 2009 | KitchenAid 30 in. Architect II Series 4.3...
My RBS275 oven has E0 F2 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#
Aug 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Some selections on the touch pad on my Jenn-air oven aren't working
Hi, There is a way to replace the keypad. Sometimes you need to replace the clock assembly. I could let you know for sure if I had the Model #
May 08, 2009 | Ovens
Oven not working Message E0-F2- showing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
EO -F2- Error?
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven temperature..
Main support number->1-800-735-5547
These people will be able to help you out.But i strongly believe this error code requires a service.Do you have a user manual for this product anyway?
May 03, 2008 | Thermador SEC302 Electric Double Oven
Amana AEW4530DDS Electric Single Oven Logo
120 people viewed this question
Top Amana Ovens Experts
Oloyede Monsuru
Joseph Hoffmann
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
