Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Not put antfreeze in my tractor - RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
If you don't use anti freeze the pump seals will harden and you will be replacing the pump every 3-4 years.
Posted on Sep 08, 2010
Intake antfreeze.leak
I hate when that happens ! if you can visually see the coolant leaking out from intake manifold @ gasket, yes it needs replaced. the gaskets. just did it to my winter car that sat outside, a lot of work , just to replace the gaskets. don't think agasket sealer would work here, intake manifold needs to come off along with alot of other things, PATIENCE is a virtue, good luck
Jan 31, 2013 | 2001 Chevrolet Venture
I need to no were to put the coolant/antfreeze/in raidator or jug
How about both? If the radiator is low you should fill the radiator and bring the level in the reservoir to its specified level however if the coolant is low perhaps you should pressure test the system and check for any leaks.
Oct 07, 2012 | 1999 GMC Savana
Antfeeze is in the oil
Genrally this is cause by the engine oil cooler mounted right above your oil filter, also a intake gasket is plastic on alot of GM vehicals.They will crack from fatigue. Let me know if i helped?
Jan 17, 2012 | Chevrolet Monte Carlo Cars & Trucks
How much antfreeze should i put in it?
Until it's full. About a quart. Make sure to use a mix that tests good to about minus 35 degrees F. A premix is a good idea also. If you mix you own, use distilled water only!!
Apr 17, 2011 | 2002 Honda CRF 450 R
How do antfreeze get inside the car where the battery is located in a1992 bmw520i
Sounds like the battery is leaking more likely. I do not know of any coolant lines that would be under your rear seat in the 1992 5 series
Jan 14, 2011 | 1992 BMW 5 Series
How do you change antfreeze
Dude you should have a drain plug on th bottom of the radiator. Remove and drain it out, run water through the system for a good ten minutes. Then reinstall drain plug and fill your cooling system with the correct antifreeze. You fill canister should be on the left side of the car and you should use GM Goodwrench DEX-COOL or Havoline DEX-COOL coolant.
Aug 11, 2009 | 2001 Oldsmobile Aurora
1998 Saturn sl 16 twin cam engine overheats.
It could be either the radator or the timeing is too far advanced. Did you put a 50/50 mixture of antifreeze? To much antifreeze vers water will also cause overheating. Non Exhaust.
May 09, 2009 | 1997 Saturn SL
How to flush the engine coolant in a Fiat Sciento?
You need water and antfreeze half and half 50/50 mixture. If damage to the raditor,it will leak outside. If damage to the engine it will leak either outside or inside into the oil,and the engine is usually badly damaged. I hope you replaced the water with the antfreeze in time.
Jan 04, 2009 | 2006 Fiat Pininfarina
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
118 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
