Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Slow acceleration low on power ih 1206 air filters new, good fuel supply turbo ok
    Problem Solver:
  • 15 Answers
Have you checked fuel filters? make sure that fuel shutoff valve is fully open, and that your fuel is clean/water-free,and hasn't cold-weather gelled
Posted on Feb 09, 2010
What causes very low power output 1994 cummins 5.9 diesel in bounder motorhome
It is possible to have a fuel injector that is stopped up or just faulty. One injector being faulty will cause the engine to idle rough or your turbo waste gate could be stuck you might have a stopped up fuel filter causing a restriction thus slowing the acceleration time down or even the air filter may need to be replaced? Any of these can be the culprit! First replace the fuel and air filter then you can bleed the injectors while the engine is running which only perform this if your engine is idling as if it were missing! It wouldn't hurt to have your truck put on a dyno if possible if not you can get a diagnostics computer to connect to your truck and with a passenger operating the diag cpu do an on road dyno test it will tell you what steps to take to test the performance of the drivetrain!
Jul 31, 2014 | 98 - 02 Cummins Dodge 5.9 Turbo Diesel...
What is turbo charger
haha! turbo charger is a unique technology used automobiles. it will add more power, acceleration to your engine. Air fuel is burned inside engine to produce mechanical energy. Oxygen is the main part of burning fuel. if more amount of air, that means more amount of oxygen is supplied fuel will burn perfectly. more air means, there is no change in air fuel ratio. that means compressed air is mixed with fuel. compressed air contains more oxygen. how can we give compressed air? the exhaust air through silencer is diverted to chamber to rotate a turbine. turbine is connected with propeller that gives more air to the air filter. thus engine is turbo charged. only problem is engine is turbo power when propeller runs more 1 lakh rpm. also there is other method called super charger. in this a pulley is directly connected with crank. the pulley is connected with a propeller using a belt. thus propeller gives compressed air into air filter chamber. thanks
Feb 10, 2011 | Suzuki XN 85 Turbo Motorcycles
I have 2000 VW Jetta 1.8 turbo, my car stumbles on acceleration, but run smooth at idle. I removed the air intake from the mass airflow sensor and the car died. Is the turbo bad or do I have another...
If you remove the mass air flow sensor then the car is getting to much air and the reason that it is dying is that the ECU is set for the engine to run with a specific air to fuel ratio, and if you have removed the breather element. or air filter then that can cause the slow or sluggish acceleration.
Jan 19, 2011 | 2000 Volkswagen Jetta TDI
Engine has been running well- oil line to fuel pump fell off-repaired but now cant strat engine= no fuel to engine-okay off pump but maybe low pressure
Fuel cutoff was stuck in closed position and sticking.opened valve and engine started but stopped again as valve closed. Lubricated valve with transmission oil and now works okay. Valve is under a light metal cover on rear end of pump on top. removd cover & found problem.No oil or fuel under cover-can run engine with cover off Now working OK after lubricated with trans oil -thanks anyway
Nov 10, 2009 | Farmall IH Tractor 706, 756, 806, 856,...
My 2003 vw jetta diesel started to run low on power and would only go about 60 mph , and about 40 up hills, when i would push down on the accelerator black smoke was pillowing from the exhaust, ive been...
YEP A BLOCKED FUEL LINE AND FILTER WILL CAUSE LOW POWER AND BLACK SMOKE UNDER LOAD.ALSO RESTRICTED AIRFLOW DUE TO DIRTY A AIR FILTER.IF REPLACING FUEL FILTER DONT HELP.YOU HAVE FAULTY FUEL INJECTION PUMP.AND PROBLEM IN TURBO WASTEGATE ACTUATOR.IT COULD BE BINDING.THE VOLKSWAGON DEALERSHIP HAS TO FIX CAR.
Nov 10, 2009 | Volkswagen Jetta Cars & Trucks
Hi, my 307 hdi 2.0 79kw, accelerate to slow, my
Clean/Change air filter, fuel filter, air filter, turbo filter. Clean and check EGR valve and Turbo gate. Check the hdi fuel pressure. Open the injectors and clean it. Give it a try and may be you can save 600 euros.
Oct 17, 2009 | 1987 Peugeot Liberte
Loss of power on acceleration. engine bucking.
check transmission fluid.change fuel filter and air filter.try changing up on where you buy gas .because bad gas causes problems.
Jun 26, 2009 | 1999 Ford Taurus
Poor acceleration
fuel filter.. or possibly the turbo that you bought is bad
Feb 21, 2009 | 1994 Eagle Talon
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
204 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Bud H
Adam Plug
Adam Plug
Are you a Farmall Toy Expert? Answer questions, earn points and help others
