Question about PNY 2GB microSD Memory Card
I can't pull up the data on it on my computer
I always have e mails in the box where it says G mail.I see now in the box and its asking for the password instead and all of the existing e mails are gone. what happened. How do i get that back.
Posted on Mar 18, 2010
  • 102 Answers
Try using a differnt card reader if you have one. It may be damaged contacts on the card or the card reader.
Posted on Feb 01, 2010
How can I transfer data from a tower that has been replaced by a new computer?
There are several ways. I'll offer you some options:
1. Connect the old and new with a special network cable and copy it over.
2. Save the data off the old one on a thumb drive. Copy the data off the thumb drive onto the new system.
3. Pull the hard drive from the old system and mount it in the new one, and copy the data over.
Any of these will work....
Feb 22, 2016 | Gateway Computers & Internet
How do I retrieve lost files on Toshiba satellite windows 7 system
If the computer was formatted and was untouched after you will need recovery software to get the data back GetDataBackNTFS is really good costs about $59. If the computer no longer boots into windows you will need to pull the drive out (Typically 2 screws on back) Should be a small panel with a picture of little discs on it. Plug it into another computer. If it is detected you can simply copy and paste to the second computer, then put the drive back into the laptop and use your system recovery discs to restore the computer back to factory default and copy your data back over. If you plug the drive into another computer and it is not detected, the drive is probably damaged and would require a data recovery company to retrieve the data this can cost from $500-2000 depending on the recovery method.
Jan 27, 2012 | Toshiba Computers & Internet
Hello, I have a Samsung 3g 2TB external hard disk drive. Sometimes it makes a knocking noise, Then the pc freezed. sometimes it dont a i can transfer data. if the pc freezed i must reset the pc.
A knocking sound means your harddrive has either a bad head or a bad sector. This would also explain your freezing up, because your computer is unable to pull data from the drive.
To ensure that all of your data is safe i would follow these steps.
1: Do not continue using the computer without backing up your data.
2: Create a folder on your desktop
3: Drag the data from the drive to your computer. ( if not possible you may need to see a specialist)
4: If the drive is under warranty contact the manufacturer, if not you may be able to return it to the store in which you purchased it.
** Just remember, the more you use it the more likely it will completely fail and your data will be lost.**
Mar 07, 2011 | Computers & Internet
Hi my hard disk is falt and then it not working how can i get that file backup T.P +940713168462
First try plugging it into another computer to see if you can read from it. If the drive does not "spin up" or constantly makes a clicking noise you most likely will not be able to get anything off of it. If it spins up and the computer recognizes it you can use a data recovery software to scrape the data off. If you cannot access it by plugging it into another computer you will need to take it to a data recovery company to have them pull the data off for you.
Mar 02, 2011 | Hitachi Computers & Internet
My computer went bad and I cannot get the data off of the storage drive. How do I proceed?
Hello Sir, hi, to access the hard drive data, you need to get the Hard drive out of your computer and place it on another computer.
to remove the drive. 1. power off the pc. 2. open the side panels to access the inside. 3. locate the Hard drive. the rectangular metal unit in front. not the CD drive okay. 4. remove the 2 cables connected to the drive. power and sata/ribbon cable. 5. loosen the screws. 6. Gently pull out the drive.
Ask a friend with a computer to help you out to get the data. or visit a computer shop to have your data back up tp a CD bring you drive along.
May 22, 2010 | Maxtor Shared Storage II (S01R320) Hard...
How do i transfer data from windows 98 formatted drives 2 xp ones
Set up your old drive as a slave and copy the data. Good luck.
Jun 19, 2009 | Computers & Internet
Maxtor 3000LE makes noise and will not show up on my computer
You will need a data recovery specialist. Hard drives making noise need to be taken apart and put into a special machine to pull what data is not damaged. The more you leave the drive on or play with it the more data is destroyed.
Jun 18, 2009 | Maxtor Hard Drive
First time trying and i cannot access my data. This is the first time I tried to pull it up.
USB is very finnicky. Shut off your computer and external drive. Unplug the USB cord from one end (which ever is easiest). Turn on your computer. When windows is up, plug in USB cable. Turn on USB drive. Windows should recognize the USB ox and drive and attach the extra drives. But, you must have windows millenium or newer. Or you will need USB drivers for the external USB box.
May 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Simpletech External Hard Drive 500GB
As far as your computer. You should be able to get the data off it. Assuming the hard drive is okay. But as far as your external.. I'm not sure . Depends on what you mean crashed. Even if, lets say, you can't use it b/c it keeps crashing in windows. Doesn't mean that you couldn't get stuff off it. So you should be able to get your data off. "should". After that you should run checkdisk /f and have it scan those drives. If they have bad sectors it will mark them and tell the computer not to put data there. Then they should be okay to use.
Feb 10, 2009 | Seagate Computers & Internet
My computer died, but
the easy way to recover your data is to take out your hard drive and connect it as a secondary drive in any other computer, then you can get back all the data. if this is not possible you can use many data recovery tools like Norton ghost, for your help. .
For Good Data Recovery Tools http://www.datadoctor.in/
Mar 20, 2008 | Computers & Internet
PNY 2GB microSD Memory Card Logo
118 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
