Question about Toshiba e-Studio 45 Black and White Copier
My e-studio 45 has 260,000 copies and says it needs maintenance. It works well. Do I just replace the drum or does it need other parts like a fuser too?
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; When it said need maintenance, it means need PM( periodical maintenance) that including drum, drum blade ,developer, corona wire, etc. the fuser and pressure roller depend on condition.
Posted on Feb 02, 2010
Testimonial: "Thanks for helpful instructions for my copier repairs. Now I know what I'm faced with and what I need."
How to reset c2557
i put in a brand new developer unit, using the new developer I had just replaced into the old developer unit, reset drum and maintenance counters, ran F8 again. The machine came into ready, ran (1) copy, jamed on fuser entry and C2557 fired again. I then reset the switch in the back (right hand side), reset the switch on the main board, reset drum and maintenance counters, ran F8 again. The machine came into ready, ran (1) copy, jamed on fuser entry and C2557 fired again.
Aug 13, 2014 | Office Equipment & Supplies
How to reset maintenance drum in toshiba e studio 200?? Please reply quickly.
You can use the Toshiba e-studio 160/200 service manual for this machine,
Enter 08 Service mode and:
check these addresses
340 Drum counter end setting. Drum Life:160 and 200 are 27,000 copies.
250 is 33,000 copies. If set to 0:Nothing displays.
673 Resetting drum related counters (08/355 and 08/401) works only if 08/869 is set to 1=SRU, if set to 0 is=CRU.
SRU: Service Replaceable Unit.
CRU: Customer Replaceable Unit.
Good Luck
Jun 27, 2011 | Office Equipment & Supplies
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
I can not get my copier to work at all it just leaves a j 3 message. When it was working black lines were being left over every copy page
where the black line being left when after the drum or before the fuser THe hot part. make a copy and stop the machine so the paper is in the middle catch it before it goes into the hot part are the lines there? be careful the toner will not be fuse your hand will smear the toner, if the lines are there you need to replace the cleaning blade and maybe the drum and get the image unit that houses the drum might need to be cleaned.
if no lines then the fuser is putting the lines on the copy replace the upper and lower fuser rollers and cleaning roller next to the lower fuser roller.
try this site as star to get parts.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 18, 2011 | Minolta EP1083 CS/PRO Copier
What part number do I need to replace the fuser E on a OKI B6300N? Is this the same thing as a drum?
The drum is not the same as the fuser unit. The fuser is sold as part of the maintenance kit. I've found two part numbers: one for a printer that uses 110 V: OKI-50230120, and one for 220V printers: OKI-50230130.
The drum holds the toner from the toner cartridge; the fuser heats up and locks the toner to the paper. http://www.fastprinters.com/oki-supplies.asp is one source that seems to still have these in stock for both power configurations. However, I found several links for the 110V version with Google. (Some have it in stock; others don't).
I hope this helps.
Sep 08, 2010 | OKI B6300n Printer
How i will enter in Sharp Ar 5316 photocopier machine programing and how i will remove maintenance sing
Hallow there, it is always good to understand a specific code and what it means because not all codes are cleared using simulations. Maintenance sign means that the copier needs to be well serviced and checked if something is to be replaced. Consumables such as drum, blade, fuser rollers and developer are changed at such times. If you are sure that you have replaced the correct part or nothing is to be replaced, then you can proceed to clear the sign.
Follow this procedure to clear maintenance sign; Press #, Interrupt, C, Interrupt. keys in that order. Enter 20 and press copy key then enter 01 and press copy key again then press CA key twice to return to normal mode. Wish you success.
Aug 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
Oct 05, 2009 | Kyocera Mita KYOCERA/MITA AS-M4110 Copier
Konica di620 ghosting and streaking
What about the starter/developer last time its been changed? Upper fuser/fixing roller (Hot rollers) don't forget to clear counters once those parts are installed.
Aug 05, 2009 | Sharp AL 1631 Copier
Replace Fuser Reset
For the MFC 8860, I turned off the printer. I help down menu. I turned on the computer. It entered Maintenance mode. I typed in 88 (Parts Replacement.) I scrolled to the fuser, clicked ok. Then, I turned off the printer. When I turned the printer on, it said that I needed to replace my laser. I then turned the printer off, help down menu, turned the printer on, typed in 88 at the maintenance menu (parts replacement), scrolled down to laser, and hit ok. I then turned the printer on and off, and poof, now it works. I find it quite unscrupulous that I had a replace PF Kit1, replace Fuser, and replace laser messages all within one hour...
Jul 15, 2008 | Brother MFC-8860DN Printer
Monroe 946 copier
The drum cleaning blade is located in the drum unit and is very much like a windshield wiper blade on your car and even has the same function. It cleans the drum of toner residue after each copy is made. A positive test to see if the drum blade is worn is to make two or three copies of an original and if the streaks are worse on the second copy and worse still on the third copy, then you can be fairly certain that your drum blade is bad and needs changing. Not a simple task, probably best left to a technician. You can do some serious damage to the drum if you're not careful. If the test that I described indicated that the drum blade isn't bad, then the next most common problem is a worn heat roller in the fuser. Not an easy thing to replace either. You can check this by making a copy and stop the machine just as the copy just reaches the exit rollers of the machine. After removing the copy, you can see that part of the copy has been through the fuser, the part of the machine that gets hot, and part has not reached the fuser. If the lines are on the copy that has passed through the fuser, but aren't there on the part of the copy that hasn't reached the fuser, then you can be sure that the lines are caused by the fuser roller.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 28, 2007 | Office Equipment & Supplies
Toshiba e-Studio 45 Black and White Copier Logo
343 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
