Question about Kenmore 42926
WHEN I PUT THE LID DOWN TO THE MACHINE THAT PART/PIECE IS DAMAGED/BROKEN. I NEED TO KNOW THE ECACT NAME TO THAT PIECE. MY MACHINE IS A KENMORE MODEL # CR1145923
    President:
  • 1,937 Answers
This assumes that you have a KENMORE top load, direct drive, neutral drain washers are made Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The part that I think you're speaking about is called the Lid Switch.
See the following for how to release the console and cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0889d158da595eb215b7c9c2cba82d17
Posted on Feb 01, 2010
My Sears Kenmore Heavy Duty Plus Washing Machine Model 110 - 16512690 fills with water, evacuates water, but will not spin or agitate even though the switch at the top is pressed down.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11016512690/0582/0153200?pathTaken=
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Dec 07, 2010 | Kenmore Washing Machines
My washer stopped working how do i know its the coupler.
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
spinning.
Before pulling the cabinet however, I'd test the Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Apr 09, 2010 | Kenmore 23822 Top Load Washer
Kenmore 70 Series Washing Machine Just Hums (Won't Agitate)
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22712100
Also see the Whirlpool / Kenmore service manual.
Initial thoughts are a worn/broken motor coupler.
See the following for how to get to it and check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=6019c5e82bfa177df953f5d6ebeac983
It's possible that the prongs have broken and the humming that you hear is the pieces rubbing against the center rubber piece.
Jan 10, 2010 | Kenmore Washing Machines
Kenmore 70 series washing machine that has a terrible smokey smell. Now my clothes have that horrible smell. What could the problem be and is it worth fixing.
Top load direct drive whirlpool / kenmore washers use a Motor Coupler between the motor and transmission.
The coupler consists of two plastic pieces with a rubber piece between them.
If the plastic pieces are broken, you may be smelling the rubber piece "burning"
Following is a description of how to access the coupler and check it.
It's a relatively inexpensive piece and is designed as a fail safe between the motor and transmission.
It's very easy to replace if necessary.
Nov 25, 2009 | Kenmore Washing Machines
I have a Kenmore Elite model # 110 26962500 that fills with water but will not agitate unless you slam the lid down or hit the lid with your hand very hard. It seems to be the lid switch but I do not want...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26962500+
Getting to the Lid Switch on these machines is about a 5 minute job.
First, unplug the machine.
Looking at the Sears diagram for the console, you'll see that underneath the corners of the console are two clips. Using a thin putty knife, push on these clips from the front and the entire console should tilt backward.
Looking at the diagram for the cabinet, you'll see the lid switch.
Although most top load / direct drive Whirlpool / Kenmore washers only use the lid switch during the spin mode, yours may be a bit different.
See the following Whirlpool service manual for the top load direct drive washers.
Usually, the problem with these washers not agitating points to the Motor Coupler.
Since you already have the console tilted back, it's another 5 minutes to pull the cabinet off and check the coupler.
See the following.
If the coupler is worn or damaged, replacing it takes about 10 minutes .
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. Hitting the cabinet may allow the coupler to grab and transmit power.
Oct 26, 2009 | Kenmore Washing Machines
Model 20 doesn't spin
WHAT PLASTIC PIECES? YOU MEAN THE COUPLERS ON THE BOTTOM OF MACHINE? HAVE YOU CHECK THE LID SWITCH?
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine series 7 does not release the water.
check your lid switch and see if it is there any more. it is possibly broken. the way you locate this is to look at your lid usually there is a white piece that is long attached to it. that piece plunges into the lid switch and you should be able to see it. if not and it is a hollow hole. then there is your problem let me know if you have any other questions
Jun 04, 2009 | Kenmore Washing Machines
Washer will not spin sometimes/ Safety switch broken and I need to lift the lid to install new switch. Any suggestions?
If you are talking about replacing the lid switch, the following link explains how to remove the washer case to access:
http://www.fixya.com/support/r385198-replacing_lid_switch
The intermittent spin cycle problem is generally a clue that the lid switch may be malfunctioning in some way. If you've already diagnosed this to be your problem, then the link I provided will give you the necessary guidance to complete this repair. If you have any questions along the way, please let me know. I hope this is helpful to you.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
We need to replace the switch that allows the spin cycle to work with the lid down. The back is one solid piece we dont know how to get to the timer to plug in the new switch we bought
What you are talking about is called the "lid switch". The following link explains how to replace one on a Kenmore top loader:
Make sure you check to see if the switch is simply loose. There should be some mounting screws holding it in place. In addition, there is usually a small plastic piece mounted on the washer lid on most Kenmores that activate the switch when the lid is closed. This is called a "lid strike". If the mounting screws are loose, or if the lid strike is broken or missing, the washer will exhibit the same symptoms as having a broken lid switch. For replacement parts, refer to searspartdirect.com and type in your complete model number (located along the washer lid opening). The parts you need will be listed under the "Top and Cabinet" heading.
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 11, 2008 | Kenmore Washing Machines
Kenmore 110 Series 90 stops at the rinse cycle full of water
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. hence, the reason why you can get it to work sometimes by lifting and closing the lid. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: For future reference, it is strongly recommended that you do not slam the washer lid or place heavy objects on the lid. This can cause damage to the lid switch.
Aug 18, 2008 | Kenmore 15944 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
