LG DLG5932W Gas Dryer Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer wont heat and check filter light is on but filter in dryer is clean?
Anonymous
Level 2:
  • Expert 311 Answers
  • Posted on Feb 01, 2010
Anonymous
Expert
Level 2:
Answers
311
Questions
Helped
69953
Points
991
This could be caused by a venting restriction. These dryers have sensors built in to check airflow temp differences. Take the vent off the dryer and run it and see if it heats. If it does then you know the problem is with your venting. You will need to either clear the vent or replace it.
Hope this helps _MJ_
Bosch Maxx7 sensitive - WTV74100ME/15 - stop after 1 minute , 3 beeps all the time , flushing lights together for heat and open door icon.
The issue you are experiencing with your Bosch Maxx7 sensitive dryer could indeed be related to a faulty heat sensor or a clogged vent. Here are a few troubleshooting steps you can try:
  1. Check the vent: Ensure that the dryer vent hose is not clogged or blocked. A blocked vent can prevent hot air from circulating in the dryer and trigger the overheat sensor to shut down the machine.
  2. Clean the lint filter: Remove the lint filter and clean it thoroughly. A clogged lint filter can also cause the dryer to overheat and shut down.
  3. Check the heating element: If the heating element is faulty, the dryer may not heat properly or may overheat and trigger the sensor to shut down the machine.
  4. Reset the machine: Turn off the power to the dryer for a few minutes and then turn it back on. This may reset the machine and resolve the issue.
If none of these troubleshooting steps resolve the issue, it may be best to contact a qualified technician to inspect and repair the machine.
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out appliancepartspros.com or repairclinic.com for how to videos and parts.
Dryer wont heat
Sounds like your heating element has went out. So you will either have to replace it $100 to $150 or purchase a new one
Light flashing says check filter. Dryer wont heat up? What filter and where is it located
The filter screen check light is just a reminder indicator. It will always come on whenever you turn on the power. As for the heat, you didn't state whether it's electric or gas.
Jul 15, 2011 • LG Dryers
2helpful
DLG2532W dryer not heating up. check filter light is on, but all filters are cleaned.
We have the same dryer and the check filter light always comes on at power up but goes off when starting. Is yours still not heating? as I see you question is a little old now. let us know.
Tim
2answers
Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
Apr 04, 2010 • Dryers
1helpful
3helpful
2answers
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 • LG Dryers
15helpful
4answers
My lg tromm DLG3788W gas dryer is not heating, it says check filter. other wise it works fine. where is the filter at, i know the one where i open the door and clean the vent everytime i use it. thanks
I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
4helpful
2answers
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
