Question about Toshiba Satellite L355-S7811 Notebook
My battery charger for my toshiba satellite L355-S7900 won't work
  • Hamilton's UK
    Hamilton's UK May 11, 2010
    have you tryed to use to laptop without the battery in and just the charger cable in
    Problem Solver:
  • 9 Answers
You need to have the pins tested to see if the notebook is still sending a current to charge the battery. Take to a electroic shop and ask them to test the battery pins in the battery compartment. They will know how much current is needed to charge the battery. If the current is not their or not enough, you will have to send your notebook in for repairs. The Motherboard will need to be replaced.
Posted on Feb 01, 2010
Problem with Toshiba laptop
It stays on with Battery? Has the AC jack been damaged due to pulling on the cord while plugged in? Have you tried another cord/charger with the EXACT same power specs? Does the cord/charger charge the Battery? Charge LED lights? It sounds like a Graphics Adapter? If you connect to a external monitor is it the same. Your question/statement indicates multiple issues. 1 , Power, 2, Graphics. Can you clarify "color blank"?
May 22, 2013 | Toshiba Satellite PSLD8U-00G001 L355-S7831...
Toshiba satellite l355
If it works on batter for a while, it is not either the motherboard or the cpu
May 22, 2013 | Toshiba Satellite L355-S7831 laptop ac...
Toshiba satellite L355-S7812 keeps restarting when AC Adapter is plugged in
Hi Craig,
The car adapter may be the culprit.
If it's not the adapter recommended by Toshiba, than You are heading the quick way to pickling your Laptop.
Always use the brand recommended for you PC/Laptop.
Cheers,
Peter
Feb 18, 2013 | Lifetime Toshiba Satellite L355-S7812...
Toshiba satellite won't go on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 01, 2012 | Toshiba Satellite L355-S7811 Notebook
Toshiba satellite L355-S7915 is not charging properly. How can
check charge with a next toshiba laptop to see if charge is good, if so you may need to get the charging port replaced
Aug 04, 2012 | Toshiba Computers & Internet
I have a Toshiba Satellite L355-S7915 and the audio driver is not working. How can I fix this?
Sounds like an old driver or something. Try this tool drivermax to help you find the lastest audio driver http://www.drivermax.com/download.htm
Oct 06, 2011 | Toshiba Satellite L355-S7915 Notebook
Can i replace a toshiba l355-s7901 motherboard with a toshiba l355-s7915 motherboard
Going out on a limb here, but I'm going to state yes, except the s7901 has hot keys in the center strip under the LCD screen. Above the Keyboard, where the Power On button is located. The s7915 doesn't.
Toshiba Satellite l355-s7901,
http://www.notebookcheck.net/Toshiba-Satellite-L355D-S7901.14988.0.html
You can click on the photos towards the bottom to enlarge.
Toshiba Satellite l355-s7915,
http://www.notebookcheck.net/Toshiba-Satellite-L355-S7915.19879.0.html
Same with the photos at the bottom.
I know this doesn't seem like a very professional answer/solution, but in viewing both of the laptops the ports, (USB, DC Power Jack, etc.), and the peripherals, (DVD optical drive, add-in card drive, etc.), seem to be in the same place.
Viewing a Service Manual for the Toshiba Satellite l350 series of Notebook PC's, shows removal procedures to be the same across the board, no matter what model deviation it is.
As long as it's one of the Satellite l350 series.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the second Satellite file header. The one that starts with Satellite A10.
Now go down to the second line, and then go across to L350, and click on it.
This is a PDF file. May take up to 30 seconds before you see the first page, and additional time to fully download.
Do I know for a fact they will interchange? No, I do not.
I'm willing to bet strongly that they will.
Nov 20, 2010 | Toshiba Computers & Internet
Toshiba Satellite L355-S7811 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
