Question about Dell Dimension 2350 PC Desktop
The dell dimentions 2350
The computer starts but then stops on its own
  • word_warrior May 11, 2010
    can you give a few more details?
  • 102 Answers
Ensure that both the case fan and CPU fan are dust free and spinning. I think it could be overheating and then shutting itself off to prevent damage
Posted on Feb 01, 2010
Dell dimention 2350 socket 478 I upgrade celeron 2.0Ghz to pentium 4 3.0Ghz 530 The Bios show me the speed 1.5Ghz. Bios A02
The Dell Dimension 2350 Desktop PC motherboard, has an Intel 845GL motherboard chipset,
mounted to it. (System Information),
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1101572
Here we see that the Intel 845GL chipset supports processors, with a -> maximum <- Front Side Bus of 400MegaHertz, (FSB = 400MHz max.),
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
The Intel Pentium 4 model 530 (3.0GHz. Also has Hyper-threading Technology. HT), operates with a FSB of 800MegaHertz, (FSB = 800MHz),
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
(Scroll down. Pentium 4 HT 530 )
You can't make the Intel 845GL chipset support a processor with an 800MHz FSB.
BIOS update or not, the voltage range will be too low. Therefore the FSB is low. Changing just the Multiplier will not do the trick either.
(BIOS Setup, Advanced Chipset Setup. Doubt the options of changing the FSB, and/or Voltage, and/or Multiplier, is available with that BIOS program))
Note your 3.0GHz processor is operating at 1.5GHz?
Max FSB supported is 400MHz, and your Model 530 needs 800MHz? (For max operation)
Post additional questions in a Comment.
Regards,
joecoolvette
[ Chip and Chipset are shortened terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The motherboard chipset technology used for your computer, has a Northbridge chip, and a Southbridge chip.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors )
The Northbridge chip handles the faster capabilities of a computer.
Processor, Ram Memory, and High-speed graphics.
[ The AGP technology, and the PCI-Express technology, is High-speed graphics.
Using a graphics card in a PCI slot, or using Integrated Graphics, is NOT High-speed graphics ]
The Southbridge chip handles the slower capabilities of a computer.
Anything connected to the PCI bus, (Such as a PCI graphics card)
IDE (PATA)
SATA
USB
Ethernet
Audio (Sound)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[ CPU stands for Central Processing Unit. Another term used is Microprocessor, or Processor for short ]
So it is first up to the Northbridge chip, of the motherboard chipset, whether it will support a certain processor, THEN if a BIOS update will help.
Nov 12, 2011 | Dell Dimension 2350 PC Desktop
When i start my dell 2350, i get a spoolsv.exc error. then it just restarts, and gives the same error over and over
good day, i strongly advice that you reformat your computer because its bugging down the system. have a nice day
Feb 04, 2010 | Dell Dimension 2350 PC Desktop
Router dell 2350 not detect by computer
open a explorer session go to tools/ internet options/connections/lan settings check off Automatically detect settings click ok, ok close explorer then open a new session and see if you get internet.
Oct 17, 2009 | Dell Wireless 2350 Router
Front panel usb and controls for dell 2350 dimention motherboard pinout
Same as standerds. In the internal usb conector u can find that there is one pinless & four pin for connect usb.at the pinless side after the pin u put the ground & same line on the opposite u put the red wire.
Jul 28, 2009 | Dell (2336V) Motherboard
My CPU fan for my Dell Dimension 2350 has stopped turning!
If your fan is not turning at all then it is probably dead, the bearings are likely clogged with dust and such. The PC is shutting off because of heat buildup on the processor chip. You need to do an Ebay search for your model and order a fan right away. Continued running of your sysem without a fan will kill the processor and motherboard. You should be able to get a replacement fan for your computer for less than $15 including shipping. Your local computer store may have one to fit your system but they may charge more for it. To change the fan is very easy, the left side of the case will come off your system, right under the power supply is the processor and heatsink and the fan. Disconnect the old fan and reconnect the new unit.
I hope this helps, if so please rate my solution
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 02, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
Sound driver
you can find all the drivers for your computer here,
just go to the audio section
Jul 18, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 PC Desktop Logo
79 people viewed this question
Alun Cox
