Question about Boating
My fishfinder screen has lines through it that makes it hard to read it
  • 64 Answers
This means that the LCD is failing. Call your local marine electronics dealer and see if they have any replacement LCDs for the model fishfinder that you have.
Posted on Jun 14, 2010
Why is Raymarine DS500x screen browning?
Typically I have seen this for units that have been overheated - such as left out in direct sunlight when not in use.
Jul 07, 2014 | Raymarine Ds500x Color Fishfinder: Ds500x...
Humminbird
My 787c2 screen just shows lines across it does anyone know were to get a new screen for it hummingbird says they don't stock them anymore try Humminbird Fishfinder Depth Finder Humminbird GPS Chartplotters...
Jun 14, 2013 | Humminbird Boating
Somehow I have split the screen into two pictures of the same sonar reading. How do I get it back to only being shown on the one screen instead of being split into two.
Hi, press pages, then use the arrow up key to select sonar only page(it will show in upper left of screen the page you have selected.) Then press enter. Hope this helps, regards Phil.
Jul 20, 2011 | Lowrance HDS 5x Fishfinders HDS 5x...
The display has hosizontal lines and/or lines with missing content. Hardly readable. Anything to be fixed?
Hi:
This is an indication of a bad display driver IC, it is better to just replace the unit as you probably will not be able to get parts for this unit.
Apr 17, 2011 | Garmin Fishfinder 100 GPS Receiver
Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Jul 08, 2010 | Garmin Fishfinder 90
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Screen fog
Hi there... mine did the same the very first morning I took it out. I rang and sent it to the manufactures. It was a very common thing and they fixed it within 10 days. I have not had a problem since. It should not of happened in the first place though. I have read a heap of forums on this exact matter and i think you would be the 10,000 person with this very problem. I have also had big problems with my transducer... so overall I am not impressed with Raymarine.
All the best mate.
Jan 02, 2009 | Raymarine Ds500x Color Fishfinder: Ds500x...
The unit does not turn on.
Hello vfedele5, The plug on the unit itself maybe the culprit. Check the voltage during power up, a resistance in the power line may be present. If the unit passes these test you have an internal connection error, bad internal connection, solder connection, ect. Merry Christmas.
Dec 07, 2008 | Raymarine Ds500x Color Fishfinder: Ds500x...
False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
Feb 25, 2008 | GPS
Boating Logo
149 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
