Question about Polaroid FLM-3225 32 in. LCD Television
Why don't my tuner work when I connect it to the antenna?
    President:
  • Polaroid Master
  • 1,779 Answers
If your on cable it will work! If your on outside antenna it Won't.! You do not have a ATSC tuner in that model to recieve digital signal over the air.
Posted on Feb 01, 2010
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
Getting the tuner to work
maybe you have an antenna problem, check for loose antenna wire at the back of the receiver, if thers a frying sound you need to connect the antenna
Jan 20, 2014 | Kenwood Audio Players & Recorders
The aerial port does not work.
It is possible the tuner or antenna connection is bad---If you can call up the menu with the remote set needs to be switched from cable etc to air or antenna and channels programed------not on the rear input connection but for the tuner in the set (presume it has a tuner if antenna connection of any type is there.
Oct 29, 2012 | Televison & Video
Proview 3200 wont work w/ outside antenna
I don't think it has ATSC tuner at all. In other words I don;t think it will work with an inside antenna either.
or if it does...just use the inside one :-)
Oct 01, 2012 | Proview Televison & Video
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
How do you connect the antenna and get channels to work?
First make sure that your Input is TV. Use the Input button on the remote (to the right of 0) or on the side of the TV (lowest button). To watch OTA channels, after connecting the appropriate antenna for your location with a coaxial cable to your Antenna In port, press Menu then use the arrows to select the Setup submenu. Press Enter to access the submenu and select Installation. Then select Terrestrial and then Input Configuration. Here select Antenna as your input. Press Enter to save. Then scan for channels by returning to the Terrestrial sub menu and select Channel Program to scan all available channels.
Since digital signals are either sufficient for your tuner to interpret or give No Signal, you need to select your antenna and point it with care. Go to anntennaweb.org or tvfool.com to get information on the stations that you should be able to get in your location. Antennaweb assumes an outdoor antenna but still gives a conservative list of available stations. TVfool gives stations depending on the color code of the antenna (indoor, outdoor, amplified) and their directions. If you are sharing the antenna signal with multiple TVs, you may need an amplified splitter. (If you do have an amplifier, you may want to test removing it from the line and directly connecting the 37HL17 to the antenna. When amplifiers get damaged they can turn into signal filters which block the signal completely.)
If you have the correct antenna, check if another TV receives the stations. If so, you may have a bad tuner on the TV. (Some TVs have better tuners than others and pick up the stations even with lower signal strength.)
I hope this helps.
(I use an outdoor antenna and antennaweb indicates that I should only get the stations from 10 miles away. I actually get those from 30 miles away as well. When I set up a neighbor's TVs with indoor antennas, one only gets the stations 10 miles away and the other gets the stations that are 30 miles away. The two antennas couldn't be rotated to the same direction.)
Nov 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Do i need a tv tuner to receive an internet tv signal?
No need,you must have only the antenna for internet,like smart broadband to watch online channel all you want to do is look only for the website that has an available online channel. It is also possible to installed a TV tuner to your computer but the antenna you will used is the antenna for TV(coaxial cable). The Antenna for internet and the TV tuner is separated, it is not the same antenna.
Hope this simple information could help you to solve your problem. Mam/Sir don't forget me to rate me up I really appreciate what grade will you given to me. Thanks a lot and God Bless.
Jul 14, 2011 | Computers & Internet
I am trying to turn on my sirius radio (it has been working for 1 year) and all of a sudden it says 'check sr tuner'. Everything seems to be plugged in right yet it still won't turn on. Any ideas?
Page 62: If "CHECK SR TUNER" or "ANTENNA ERROR" appears in
the front panel display, the connection of the SiriusConnect
tuner or antenna is incorrect. In such cases, check the
connection of the SiriusConnect tuner and the antenna (see
page 115).
• If "NOT SUPPORTED" appears in the front panel display, this
unit does not support the connected SiriusConnect tuner.
Or the SR Tuner is fluky. Refer to its manual and start over with IT as the product, not the Yamaha.
Jul 13, 2010 | Yamaha RX-V663 Receiver
Polaroid FLM-3225 32 in. LCD Television Logo
54 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
