Question about Refrigerators
Does not run
Opened the door and the light was out and no sound was coming from the unit. It's 1 1/2 years old. I plugged it into another outlet and nothing happened.
  • jwright540 Feb 02, 2010
    Good steps to follow, but I tried all of those and none of them worked. Thanks for the response.
    Scholar:
  • 91 Answers
Check an reset your fuse panel box, the other outlet you use might be off an also in the same circuit , i would reset the breakers an try it again, sounds like an outlet problem
good luck and leave some feedback thanks !
Posted on Feb 01, 2010
I have a FFU17F5HWB Upright Freezer. It will run fine for a period of time, but we will look and the temp light on the door will be on and digital readout will be "-". When I unplug and plug back in t
Sounds like you have voltage issues that are messing with the electronics on the unit. A voltage drop or spike could cause the problem. Overheating or a just a bad temp control could also be a issue.
Oct 29, 2014 | Freezers
The dash lights and all rear running lights go out when the drivers door is opened.
Replace battery if more than 4 years old. Colud also be a shorted or grounded wire comin thru door.
Aug 05, 2012 | 2002 Kia Spectra
No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Jul 16, 2012 | Microwave Ovens
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Controll pannes has dim lights and wont respond to touch
It sounds like a bad timer board . If you unplug overnight you allow discharging the capacitor on control board, that is the reason why it works next day. Check if the power outlet is grounded properly, and test a different outlet. If that does not fix the problem, then test and eventually replace timer board, motor control unit or any other control board present (dryness control if present).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 02, 2009 | Whirlpool GEW9250 Electric Dryer
The microwave just stopped working in the middle of heating
Always have something in the microwave before turning on. A glass of water is OK. It's needed to absorbed the energy.
All microwaves will stop if the door is opened. This a safety feature. Never operate with the door opened.
The button below the plug outlet is a test button for the GFI (Ground Fault Interrupter). This is a safety feature of the electrical wiring for your home. Make sure it's turned on.
Since this is a new unit, you may want to take it back to the store you bought from for an exchange/refund.
WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance Warranty Notes For models produced on or after January 1, 2006
See written warranty for full details
Mar 30, 2009 | General Electric JES0736SMSS 700 Watts...
Lights flicker and door stops. both up and down.
do you have a duplex outlet that unit is plugged into? Try plugging a lamp into other outlet and see what happens to it when you run door, watch torque settings. they effect safety.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Dec 10, 2008 | Microwave Ovens
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
