the hose from the drum to the pump, and from the pump to the drain, are at the front,
Movement of the drum during wash cycles, wears the short hose between drum and pump and it develops cracks, eventually a wash load of any size will finally cause one of the cracks to penetrate through the rubber, and constant drip occurs.
Its an easy fix, no more than screwdrivers needed.
the local parts guy will have the hose, even if it is labelled ge frididaire whirlpool the same hose is common to many makes and models
- turn off water unplug washer
- pop the endcaps off the control panel, and completely remove the phillips head screw under each endcap
- lilft the control panel ~1inch and flip it over the back of the washer,
(do not dislodge the water level sensing hose or we'll be back to fix it later, hinges are plastic, dont bust em)
- remove the two brass clips under the control panel
(note position for reinstall)
- remove lid switch connector
- lift entire body up ~1 inch and remove forward
- motor pump hoses gearbox are now exposed.
examine hose from drum to pump, and from pump to cabinet rear,
replace cracked and crazed hoses.
reassemble in reverse order
