DAEWOO MATIZ 800CC 1999 HEATER BLOWING COLD AIR
DAEWOO MATIZ 800CC 1999 HEATER BLOWING COLD AIR ENGINE RUNNING AT NORMAL TEMP GUESS HEATER MATRIX BLOCKED ,LOOKS A JOB TO REMOVE ANY EASY FIXES
    Scholar:
  • 185 Answers
Or you need anitfreeze.
Or your thermostat is shot. Both are easy fixes.
Try the antifreeze, first,check and top off.
and if teh problem persists, check and repalce the thermostat.
Posted on Feb 02, 2010
Hi i have daewoo matiz 800cc can you help me by giving me the torque settings for the big end bearing caps please
You are looking for the torque settings for big end bearings and main bearings on a daewoo matiz?
Main bearings torques on a Daewoo Matiz 800cc (1999)
Stage 1: 25-30 Nm
Stage 2: 55-60 Nm
Big End Bearings…
Mar 09, 2016 | Daewoo Cars & Trucks
My heater blows cold air
If the car is anything approaching 10 years old or has been used without antifreeze for any period the heater matrix could be blocked. Try the 2 hoses running through the bulkhead to the heater when the engine is hot and see if they are the same. If hot and heater is cold then heater is blocked. Does the engine reach normal temp? If not check the thermostat. If you give us more vehicle history a more specific answer could be given.
Nov 04, 2015 | Cars & Trucks
I put a new heater core ,themastat,rad,anti freez,and stils blow cold air could it be coolant tempearture sensor
Does the engine actually warm up enough to produce hot air thru the heater? In other words, does the radiator get hot to the touch? Does your temperature gauge on the dash indicate a normal operating temperature , or does it show cold? Make sure the linkage from the temperature selector in the dash is connected to the water control valve for the heater.
My guess would be the engine is indeed warming up, but a faulty (or disconnected) water control valve to the heater is preventing heated water from ever reaching the heater core.
Jan 09, 2011 | 1992 Ford Crown Victoria
When first starting it starts ok but wont drive
this problem sounds like either a fuel filter or ignition coil a faulty coil pack will work fine until it gets hot from a short inside
Mar 14, 2010 | 1999 Daewoo Nubira
The oil level is correct on my 2001 800cc Matiz, yet light comes
it could be your oil preshure is not up to par or some times if your idle goes to loe it can set off your lo speshure light but i just cant be shur so give it a look but do watch it please
Sep 14, 2009 | 2001 Daewoo Lanos
Cylinder head daewoo matiz
Tighten the cylinder head bolts to 85--90 NSm (63--66lb-ft).
Jun 06, 2009 | 1999 Daewoo Lanos
What is the torque pressure for a 01 daewoo matiz 800cc head
2001 daewoo matiz 800cc
This is the best info I have.
Just as important as the torque values is the tightening sequence. Since modern engine heads are soft alloys this is key. The bolts are tighten down maybe half the final value on the first pass and then tighten down fully on the final pass.
The Sequence is; 7 1 3 5 8 4 2 6 bolts 5&6 are the flywheel side of the engine Torque values Stage 1. 40-45Nm first pass Stage 2. 85-90Nm. second pass
Since you have the head removed look for carbon build up on the pistons.
You may want to get a car service manual from the library or on the internet.
May 11, 2009 | 2000 Daewoo Lanos
Engine overheats when heater pipes connected
I think you could be right about there being air trapped in the system.
Or the heater core(radiator) is plugged.
Either way you need a pressurized radiator coolant pump to put the coolant in without air being trapped.
Although,i have seen it done by jacking the vehicle up high enough that the radiator was now higher than the heater core level, and then the coolant was put in.
But this is dangerous to try.
Jan 29, 2009 | 1999 Ford Escort
Heating & Cooling Logo
535 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
