Question about Logitech Cordless Mouse
Click function keeps working
Left click results in double or triple click.
  • 102 Answers
Usually happens with dust buildup between left click and switch causing sticking - multiple clicks. You could try cleaning it but would recommend getting a new mouse
Posted on Feb 01, 2010
    Scholar:
  • 94 Answers
Callibration settings need adjustment in your pointers.
Which OS are you running?
I bought a used apple 4 ggb. Mp3 player and its. Stuck. In. Voice. Mode.and I can't get back to main menu. Please help
Ok, the first thing you are going to try is triple click the home button. If by any chance it set to activate voice over with triple or double click, this should deactivate it. If not then go to settings, general, accessibility, the very first line should be voice over, turn it off. Notice that when voice over is active, you need to double tap everything, first tap for voice over to speak, second tap for action, is the only way to get to settings, or you will just hear the voice over all the time without any result.
Jan 07, 2015 | Audio Players & Recorders
Parts of triple beam balance
> Problem with the Web Site
> parts of triple beam balance
Click: http://www.google.ca and enter the text: parts of triple beam balance
and click to do the search. Choose from the results, to read the best answer(s).
Jun 15, 2011 | Computers & Internet
HOW TO PUT MY FAVORITES ON A SANDISK FLASH DRIVE
If you're talking about some of your web browser faves, then you can use Internet Explorer's built-in 'export' feature, or even Chrome's, so I'll tell you how to do that next. But the way I like to do it, if it's Internet Explorer, is like this:
  1. Find your 'My Computer' or 'Computer' icon on your desktop and double-click it, or, if it's not there, in your Start Menu (at bottom left, click your 'Start' button, then click on 'My Computer' or 'Computer' in the right column).
  2. Now, double-click on your 'C:' drive (a.k.a. 'Local Disk', 'System', 'Windows', etc.).
  3. In Vista and '7', double-click on 'Users'. If you're using 'XP', double-click on 'Documents and Settings', then 'Users'...
  4. Double-click on your User Name.
  5. Find the 'Favorites' folder and RIGHT-CLICK IT, then left-click on 'Send To', then left-click on the Letter assigned to your Flash Drive (':E', ':F', etc.).
  6. That's it! You should have an entire copy of your faves on your Cruzer, so go to it and check (you should be able to look through all your links; double-click some to see if you go to that page!).
NOW--the boring, old, NORMAL way (for Internet Explorer Version 8, and maybe 7):
  1. Open Internet Explorer.
  2. Click on 'Favorites', then click on the little down-arrow next to the words 'Add to Favorites'.
  3. Now click 'Import and Export', then click 'Export to a File', then 'Next'.
  4. Check-mark only 'Favorites', then click 'Next'.
  5. Your Favorites folder should come up automatically in the pop-up browser Window, so click 'Next' again.
  6. At this point, you can choose to send it directly to your Flash Drive, or wherever it's going to go by default, then find that file and copy it to your Cruzer, so--you guessed it--I'm going to tell you to just click 'Browse', find your Cruzer's 'drive letter' again from that drop-down, and then click 'Export'.
  7. Done!
When performing this procedure the 'Windows' way, be careful not to do it over twice, as you'll end up with doubles, then triples, etc. I like 'My' way because you can then go into the resulting folders now on your Cruzer and navigate through them, deleting any you see you don't want to carry around with you!
S'fun! Hope this helps! Mike
Feb 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
Trackball double clicks when I click it once.
goto Control panel, on Printers and other hardware, click mouse, slide to slower on the box 'Double click speed"
Oct 09, 2009 | Computers & Internet
Mouse double and triple clicks when I click just once?
yeah u have to replace it.thanks and take care of urself
Apr 28, 2009 | Computers & Internet
Need to change ring on fax to 3 rings. it is an hp office-jet 6110 all in one
  1. Press Menu .
  2. Press the right arrow (>) or the left arrow (<) until Advanced Fax Setup displays.
  3. Press Enter .
  4. Press the right arrow (>) or the left arrow (<) until Answer Ring Pattern displays.
  5. Press Enter
  6. Press the right arrow (>) or the left arrow (<) until the desired ring pattern displays.
    • Single rings – The fax machine answers after a single ring.
    • Double rings – The fax machine answers after a double ring.
    • Triple rings – The fax machine answers after a triple ring.
    • Double and triple – The fax machine answers after a double and triple ring.
    • All rings – The fax machine answers any ring. This is the default when not using Distinctive Ring.
  7. Press Enter .
May 09, 2008 | Office Equipment & Supplies
MX Revolution left click problem
Try a bit of compressed air - perhaps dirt is jammed under the button.
If its under warranty you might want to return it to where you bought it.
Feb 27, 2008 | Logitech MX Revolution 931689 Mouse
Logitech Cordless Mouse Logo
114 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
