Question about Brother DCP 1400 All-In-One Laser Printer
The whole paper face is light dark when it printed anything.I want free info first!
  • a_gebrehi776 Feb 01, 2010
    I took it to technician not a long time ago, he said the same things and told me he replaced tonner,that it means he did not put new one,wright?
  • 542 Answers
This is due to tonner catridge got over or near to end. Replace the tonner catridge will resolve your problem.
Revert back for more assistance.
Posted on Feb 01, 2010
  • Rajesh Pai
    Rajesh Pai Feb 01, 2010
    You are absolutely right, he replaced the refilled catridge...
How to use the Copier only, instructions please?
copy machines work by running a light along under the glass
anything on the paper is reflected and the image is captured for reproduction
so place the printed surface face down on the glass
Aug 30, 2015 | Canon PIXMA Office Equipment & Supplies
Enter service mode on Canon ImagePRESS when shutdown screen is on
Before anything you should know what a print head is? It is the helpful device in an Inkjet Printer which sprays droplets of ink onto a sheet of paper. When we talk about the working of print heads, they are really much needed asset in the printing machine. A printing device is nothing when deprived of it. The print head are supposed to deliver very small drops of ink onto the paper. Where the ink from the cartridge is transported via small tubes, and the existing heating elements in the device heat the tubes, thus creates a small bubble of ink. Also, it is determined by the heating element that what size of the drop to be applied onto the paper. If you have any difficulty caused because of the print heads, then there is none other better option than to adopt the tech representatives at Canon Printer Contact Number UK instantly. They will guide you better than any other tech service in the whole market. For more info you can call @ 0808-101-3524 (Toll-Free).
Oct 30, 2014 | Canon Imagepress C1 Color Copier,...
I900D printing lines
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Canon I900D InkJet Photo Printer
What means of po cont on canon np 6650?
PO cont means Drum Potential Control,
If po cont set to 0, it means scanner system adjust the document darkness automatically but you may face many printing problems such like auomaically over dark, over light, heizzy, dull, etc etc.
if you want to trouble free printing, please set PO-Cont to 1
Aug 11, 2011 | Canon NP 6650II Copier
What media does the LP 2844 printer use? I have been supplied a roll of labels with-out any code on them. The printer seems to be working but does not print anything. The troubleshooting guide asks if I am...
Hi An Lp printer is a direct thermal printer.
That means that if you rub the label with your nail, you should see a dark scratch.
If you place a flame under the paper it should darken.
The head heat the paper at the positions where printing is performed
Jul 03, 2011 | Zebra LP 2844 Thermal Printer
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Schiller machine is not printing
If the unit print lightly or not printing anything at all?
The most common causes for not printing ECGs is one of those:
1- Too little heat on the stylus
2- Insufficient stylus pressure on the paper
Solutions:
1- Using an insulated probe, such as a screwdriver, gently press the stylus onto the paper.
2- If a dark line appears on the paper, the problem is too little pressure, but if no dark line appears, the problem is not enough heat.
Jun 19, 2009 | RTO Schiller CARDIOVIT AT-1...
Printer says to re-insert paper face down.
You must have the default printer settings changed to "double-sided" printingor "print on Both sides".
Check in your printer properties: 'Right click' the printer icon. Select "properties", "Printing preferences", "finishing", un-check "print on both sides" (these options vary slightly by printer model, so just check around on the different buttons).
That's my best guess. :)
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing dark tshirt transfers - can't override the flipped image
Hello I think I can help you. I Would not use T shirt transfer when you make up your print I would select poster print or any other form that does not automatically reverse the image. The reason your software is designed to do this is on the regular transfer paper your laying the image down on the shirt, so for it to come out right it has to be reversed. With the dark T shirt transfer paper your peeling off the backing and putting the image face up on the T Shirt.
Dec 23, 2008 | Canon i80 InkJet Printer
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
Aug 28, 2008 | Brother HL 5140 Laser Printer
Brother DCP 1400 All-In-One Laser Printer Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
